doc title Help Center
You are here: Home > Managing Access Points > Configuring Access Points
This section describes how to configure WLANWireless Local Area Network. WLAN is a 802.11 standards-based LAN that the users access through a wireless connection. SSIDsService Set Identifier. SSID is a name given to a WLAN and is used by the client to access a WLAN network., radio profiles, DHCPDynamic Host Configuration Protocol. A network protocol that enables a server to automatically assign an IP address to an IP-enabled device from a defined range of numbers configured for a given network.  profiles, VPNVirtual Private Network. VPN enables secure access to a corporate network when located remotely. It enables a computer to send and receive data across shared or public networks as if it were directly connected to the private network, while benefiting from the functionality, security, and management policies of the private network. This is done by establishing a virtual point-to-point connection through the use of dedicated connections, encryption, or a combination of the two. routes, security and firewallFirewall is a network security system used for preventing unauthorized access to or from a private network. settings, uplink interfaces, and logging servers on APs.
For more information on AP configuration, see the following topics:
Configuring Device Parameters
Configuring Network Profiles on Instant APs
Configuring Time-Based Services for Wireless Network Profiles
Configuring ARM and RF Parameters on Instant APs
Configuring IDS Parameters on APs
Configuring Authentication and Security Profiles on Instant APs
Configuring Instant APs for VPN Services
Configuring DHCP Pools and Client IP Assignment Modes on Instant APs
Configuring Services
Configuring Uplink Interfaces on Instant APs
Configuring Enterprise Domains
Configuring Syslog and TFTP Servers for Logging Events
Opening a Remote Console
Mapping Instant AP Certificates
