Tri-Radio Mode
Aruba Central offers tri-radio mode support in ArubaAP-555, a flagship 802.11ax Access Point. In tri-radio mode or split 5 GHzGigahertz. mode, the 8x8 5 GHz radio is split into two independent 4x4 5 GHz radios. In the split 5 GHz Mode, operates on channels from 36 to 64 and operates on channels from 100 to 165.
To enable tri-radio, go to > in the AP configuration dashboard, and select the check-box.
The split 5 GHz radio can operate in the following modes:
Access
Monitor
Spectrum
Tri-Radio Events
To view the tri-radio events, complete the following steps:
1. In the app, select one of the following options:
To select a group, label, site, or all devices in the filter, set the filter to one of the options under , , or . For all devices, set the filter to .
To select a device in the filter:
a. Set the filter to .
b. Under , click , and then click .
A list of access points is displayed in the view.
c. Click an access point listed under .
The dashboard context for the access point is displayed.
2. Under , click .
The page is displayed in the view.
3. Click the tab.
A list of events is displayed in the table.
When the tri-radio mode is either enabled or disabled in an AP, the table displays the following details:
The column includes the type which can be used to filter tri-radio events.
The column includes the status of the tri-radio mode in AP.
In Aruba Central, the tri-radio feature is available only on AP-555 running Aruba Instant 8.6.0.0 or later versions. |
By default, the AP-555 operates in dual radio mode. |
