Blocked Traffic
Based on the group selection from the drop-down list, the section of the dashboard allows you to view the following information:
Blocked devices of the selected group as CSVComma-Separated Values. A file format that stores tabular data in the plain text format separated by commas. file.
The number of user sessions that are blocked. This information is displayed under .
The blocked traffic details are shown only for the APs on which the Application Visibility or DPIDeep Packet Inspection. DPI is an advanced method of network packet filtering that is used for inspecting data packets exchanged between the devices and systems over a network. DPI functions at the Application layer of the Open Systems Interconnection (OSI) reference model and enables users to identify, categorize, track, reroute, or stop packets passing through a network. ACLsAccess Control List. ACL is a common way of restricting certain types of traffic on a physical port. are enabled. For more information, see Aruba Central Help Center. |
Downloading Blocked Session Details
To download the blocked session details in the CSV format, complete the following steps:
1. In the app, set the filter to one of the options under . For all devices, set the filter to . The dashboard context for the selected filter is displayed.
2. Under , click . The visibility dashboard is displayed.
3. Click tab in the visibility dashboard.
4. To download the blocked sessions report, select the device group from the drop-down. If the device group is already selected from the drop-down on the filter bar, the page displays the group name and the number of sessions blocked for the clients connected to devices in that group.
5. Click . Aruba Central generates the CSV report with data from the last 7 days.
The CSV file shows up to 50000 blocked sessions for a single AP cluster. |
