Obtaining Token Using Offline Token Mechanism
To obtain tokens using the offline token method, complete the following steps:
1. In the page, under , click .
The page is displayed.
2. Click .
The admin user profile can view the tab which displays all the apps and tokens generated in all the non-admin user profiles in addition to the apps and tokens created in the admin user profile. |
3. Click . The pane is displayed.
4. Enter the application name and redirect URIUniform Resource Identifier. URI identifies the name and the location of a resource in a uniform format. in the and fields respectively.
5. Choose the application from the drop-down list and click to generate a new token.
6. The table displays the following:
—Token ID of the application.
—Name of the user to whom this token is associated to. An application can be associated to multiple users.
—Name of the application to which this token is associated to. For example, Network Operations.
—Date on which the token was generated.
—Click and click to revoke the token associated to a particular user. For example, if two users are associated to an application and if you want to remove access to a particular user, revoke the token associated to that user.
—Click to download the token.
Was this information helpful?
Great! Thanks for the feedback.
Sorry about that! How can we improve it?Please send your comments and suggestions
