Supported Aruba CX Switch Platforms
To manage your Aruba CX switches using Aruba Central, ensure that the switch software is upgraded to 10.05.0010 or a later version. Aruba CX switches with version 10.04.2000 or earlier might not connect to Aruba Central after ten days of operation. You must upgrade the Aruba CX switch to a recommended software version to connect to Aruba Central.
The following tables list the Aruba CX platforms, corresponding software versions supported in Aruba Central, and switch stacking details.
Provisioning and configuring of Aruba CX switch series and switch stacks is supported only through configuration templates.
Data sheets and technical specifications for the supported switch platforms are available at: https://www.arubanetworks.com/products/networking/switches/.
Was this information helpful?
Great! Thanks for the feedback.
Sorry about that! How can we improve it?Please send your comments and suggestions
