About Tri-Radio Mode
Aruba Central (on-premises) offers tri-radio mode support in ArubaAP-555, a flagship 802.11ax access point (AP). In tri-radio mode or split 5 GHzGigahertz. mode, the 8x8 5 GHz radio is split into two independent 4x4 5 GHz radios. In the split 5 GHz Mode, operates on channels from 36 to 64 and operates on channels from 100 to 165.
To enable tri-radio, go to > in the AP configuration dashboard, and select the check-box.
The split 5 GHz radio can operate in the following modes:
- Access
- Monitor
- Spectrum
Enabling Tri-Radio Mode
To enable the tri-radio mode, complete the following steps:
- In the app, select one of the following options:
- To select a group in the filter:
- Set the filter to one of the options under . Ensure that the filter selected contains at least one active access point.
The dashboard context for the group is displayed.
- Under , click > .
A list of access points is displayed in the view.
- To select an access point in the filter:
- Set the filter to .
- Under , click > .
- Click an access point listed under .
The dashboard context for the access point is displayed.
- Under , click > .
- Click the icon.
The tabs to configure access points are displayed.
- Click the tab.
The page is displayed.
- To edit an AP, select an AP in the table, and then click the edit icon.
- Click .
- Select the check-box.
- Click .
Tri-Radio Events
To view the tri-radio events, complete the following steps:
To select a group, label, site, or all devices in the filter, set the filter to one of the options under , , or . For all devices, set the filter to .
The dashboard context for the selected filter is displayed. To select a device in the filter:
- Under , click , and then click .
- A list of APs is displayed in the view.
- Click an AP listed under .The dashboard context for the AP is displayed.
Under , click .The page is displayed in the view.
Click the tab.
A list of events is displayed in the table.
When the tri-radio mode is either enabled or disabled in an AP, the table displays the following details:
- The column includes the type which can be used to filter tri-radio events.
- The column includes the status of the tri-radio mode in AP.
In Aruba Central (on-premises), the tri-radio feature is available only on AP-555 running Aruba Instant 8.6.0.0 or later versions.
By default, the AP-555 operates in dual radio mode.
