Configuring Communication Ports
| Protocol and port | Domain Names and Purpose |
Inbound Ports Traffic |
TCP 443 |
To access and manage Aruba Central (on-premises). |
For HTTPS and websocket between Aruba Central (on-premises) and devices. |
To receive AMONAdvanced Monitoring. AMON is used in Aruba WLAN deployments for improved network management, monitoring and diagnostic capabilities. messages and view data for controllers in the Aruba Central monitoring dashboard. |
TCP 22 |
For management access through SSHSecure Shell. SSH is a network protocol that provides secure access to a remote device. and cluster setup. |
For CLI between Aruba Central (on-premises) and devices. |
TCP 80 |
For browser redirect from HTTPHypertext Transfer Protocol. The HTTP is an application protocol to transfer data over the web. The HTTP protocol defines how messages are formatted and transmitted, and the actions that the w servers and browsers should take in response to various commands. to HTTPS. |
TCP 2379, 2380, 4433, 6433, and 10250 |
For communication between Aruba Central nodes in a cluster. |
TCP 4343 |
To access the setup-wizard installation. |
TCP 30633 |
To allow the devices to set up a connection with the OpenFlowOpenFlow is an open communications interface between control plane and the forwarding layers of a network. controller. |
TCP 8888 |
For HTTP-based firmware image download for CX and PVOS devices. |
Outbound Ports Traffic |
TCP 25, 456, or 587 |
Dependent on the SMTPSimple Mail Transfer Protocol. SMTP is an Internet standard protocol for electronic mail transmission. configuration for alerts, reports, and Aruba Central (on-premises) account registration. |
UDP 123 |
To access ntp.ubuntu.com. This is default destination. Users can reconfigure this port. |
UDP 161, 162 |
TCP 4343 |
For device bootstrap to controllers. |
TCP 22 |
To access nexus2.airwave.com to support connection. |
TCP 443 |
To access coreupdate.central.arubanetworks.com and allow Aruba Central to check firmware versions for automatic upgrades. |
To access images from the following registries: quay.io docker.io docker.com docker.elastic.co Quay.io traffic can originate from multiple IP ranges, refer to the article to allow traffic from Quay nodes. |
To access maps.googleapis.com to translate address. |
To access api.mapbox.com to view maps from user's browser. |
To access d1c50u1zbkqmph.cloudfront.net for CDN from user's browser. |
To access https://enterpriselicense.hpe.com for licensing. |
To access help.centralon-prem.arubanetworks.com for documentation from user's browser. |
To access the outbound internet access. |
The Aruba appliance opens multiple ports. Aruba recommends that you host the Aruba appliance behind a firewall.
