Aruba Central Online Help
You are here: Home > Monitoring & Reports > Network Health > Site Health
Site Health Dashboard
The Site Health dashboard displays details of wired and wireless devices deployed on the site. This page includes information on client connectivity statistics, change logs, health of devices, and RF health of the site.
To launch the Site Health dashboard, complete the following procedure:
  1. In the Network Operations app, set the filter to a site.
  2. Under Manage, click Overview > Site Health to launch the Site Health dashboard.
Alternatively, the Site Health dashboard can be accessed by selecting a site from the Network Health dashboard page. The Site Health dashboard displays the information listed in the table below:
Table 1: Site Health Dashboard
Content
Name
Name of the site.
Location
Location of the site.
APs
Number of APs deployed on the site.
Switches
Number of switches deployed on the site.
Gateways
Number of gateways deployed on the site.
Summary Statistics
A graphical representation of the number of clients (wired and wireless) and their bandwidth usage for the selected time range.
Change Log
A visual representation of change logs for configuration, firmware, and reboot changes in the selected time range. Select a column in the graph and click on the Config Log, Firmware Log and Reboot Log button to view detailed information logs on the corresponding events in the site.
System Health Indicators
Down Devices
This graph shows the count of devices with DOWN status. The graph displays the following information:
Total number of devices
Number of unique devices that were DOWN
Minimum and maximum device downtime.
To view more details, select a time range in the graph and click on See Devices. A pop-up window displays the details of devices with DOWN status and their Up and Down time in percentage. You can also add other metrics such as CPU, Memory, 5 GHz and 2.4 GHz Channel Utilization, and 5 GHz and 2.4 GHz Noise Floor by clicking on the Add Metric button. A particular device can be filtered from the list by clicking on the filter icon ()and entering the name of the device.
High CPU & High Memory
This graph shows the total count or percentage of devices with high CPU utilization and high memory utilization.
High CPU Utilization—This graph displays the total number of devices, number of unique devices with high CPU utilization, and minimum and maximum number of devices with high CPU utilization. You can also view the total count or percentage of maximum and minimum number of devices with high CPU utilization for a specific time when you hover your mouse over the graph.
High Memory Utilization—This graph displays the total number of devices, number of unique devices, the minimum and maximum number of devices with high memory utilization. You can also view the total count or percentage of maximum and minimum number of devices with high memory utilization for specific time when you hover your mouse over the graph.
Threshold Setting Widget—You can also choose to view the graph details based one of the following criteria by clicking the (Threshold Setting Widget) icon and selecting any of the following options:
>70% CPU utilization
>80% CPU utilization
>90% CPU utilization
>70% memory utilization
>80% memory utilization
>90% memory utilization
To view more details, select a time range in the graph and click on See Devices. A pop-up window displays the details of devices with high CPU utilization and memory utilization with their individual minimum and maximum values. You can add other metrics such as 5 GHz and 2.4 GHz Channel Utilization , 5 GHz and 2.4 GHz Noise Floor, and Device Down time for the devices by clicking on the Add Metric button. A particular device can be filtered from the list by clicking on the filter icon () and entering the name of the device.
RF Health Indicators
5 GHz Utilization and Noise
This graph displays the total count or percentage of devices with high channel utilization and high noise floor levels for 5 GHz band.
Device Details—The graph displays total number of devices, number of unique devices with high 5 GHz channel utilization and high noise floor levels, and the minimum and maximum number of devices with high channel utilization. You can also view the total count of maximum and minimum number of devices with high 5 GHz channel utilization and noise for a specific time when you hover your mouse over the graph.
Threshold setting—You can also choose to view the graph details based one of the following criteria by clicking the (Threshold Setting Widget) icon and selecting any of the following options:
>60% 5 GHz Utilization
>70% 5 GHz Utilization
>80% 5 GHz Utilization
>-75 dBm 5 GHz Noise
>-80 dBm 5 GHz Noise
>-85 dBm 5 GHz Noise
To view more details, select a time range in the graph and click on See Devices. A pop-up window displays the details of devices with high CPU utilization and memory utilization with their individual minimum and maximum CPU utilization values. You can add other metrics such as CPU, Memory, 2.4 GHz Channel Utilization, 2.4 GHz Noise Floor, and Device Down time for the devices by clicking on the Add Metric button. A particular device can be filtered from the list by clicking on the filter icon () and entering the name of the device.
2.4 GHz Utilization and Noise
This graph displays the total count or percentage of devices with a higher channel utilization and high noise floor levels for 2.4 GHz channel.
Device Details—The graph displays the total number of devices, number of unique devices with high 2.4 GHz channel utilization and noise floor levels, minimum and maximum number of devices with high channel utilization and noise levels. You can also view the total count of maximum and minimum number of devices with high 2.4 GHz Utilization and Noise for a specific time when you hover your mouse over the graph.
Threshold Setting widget —You can also choose to view the graph details based one of the following criteria by clicking the (Threshold Setting Widget) icon and selecting any of the following options:
>60% 2.4 GHz Utilization
>70% 2.4 GHz Utilization
>80% 2.4 GHz Utilization
>-75 dBm 2.4 GHz Noise
>-80 dBm 2.4 GHz Noise
>-85 dBm 2.4 GHz Noise
To view more details, select a time range in the graph and click on See Devices. A pop-up window displays the details of devices with 2.4 GHz channel utilization and 2.4 GHz noise floor with their individual minimum and maximum values. You can add other metrics such as CPU, Memory, 5 GHz Channel Utilization, 5 GHz Noise Floor, and Device Down time for the devices by clicking on the Add Metric button. A particular device can be filtered from the list by clicking on the filter icon () and entering the name of the device.
NOTE: The threshold setting widget (Threshold Setting Widget) is visible only when you bring the mouse pointer closer to its position slightly above the right-hand side of each graph.
