Aruba Central Online Help
You are here: Home > Managing Switches > Configuring Aruba Switches > Disabling SNMP on AOS-Switches
You can disable SNMPSimple Network Management Protocol. SNMP is a TCP/IP standard protocol for managing devices on IP networks. Devices that typically support SNMP include routers, switches, servers, workstations, printers, modem racks, and more. It is used mostly in network management systems to monitor network-attached devices for conditions that warrant administrative attention. on AOS-Switches. Disabling SNMP will remove all the existing SNMP configurations.
To disable SNMP, complete the following steps:
- In the app, select one of the following options:
- To select a switch group in the filter:
- Set the filter to a group containing at least one switch.
The dashboard context for the group is displayed. - Under , click > .
- Click the icon to view the switch configuration dashboard.
- To select a switch in the filter:
- Set the filter to or a group containing at least one switch.
- Under , click > .
A list of switches is displayed in the view. - Click a switch under .
The dashboard context for the switch is displayed.
- Under , click .
The tabs to configure the switch is displayed.
- Click > . The page is displayed.
- Select as from the drop-down to disable SNMP.
Changing SNMP mode from or to displays a confirmation message window stating that changing SNMP mode will remove existing SNMP configuration. Type REMOVE in the text box and click .
- Click .
