Aruba Central Online Help
You are here: Home > Monitoring & Reports > Network Overview > Switch > LAN > PoE
Switch > LAN > PoE
In the switch dashboard, the PoE tab displays details, such as, PoE status summary, PoE ports, and PoE consumption.
The PoE tab displays the following details:
Viewing the LAN > PoE Tab
To navigate to the PoE tab in the Switch dashboard, complete the following steps:
  4. Under Manage, click LAN > PoE.
    The PoE tab is displayed.
    You can change the time range for the PoE tab by clicking the time range filter and selecting one of the available options: 3 hours, 1 day, 1 week, 1 month, or 3 months.
The PoE tab is displayed only if the AOS-Switch or the AOS-CX switch supports PoE.
The PoE tab displays monitoring data only if the AOS-Switch firmware version is 16.08.0001 or later.
PoE Status
The PoE Status section displays the following details:
  • Available—Power available for consumption for the switch or stack.
  • Used—Power used by various devices.
  • Remaining—Power remaining to be utilized in the stack or device.
  • PoE Denied Ports—Number of ports for which power is denied.
  • Alerts—Number of alerts generated.
Faceplate
If the switch is a standalone switch, the faceplate of the switch is displayed. For a switch stack, faceplate of all the switches part of the stack is displayed. From the faceplate, click on the port to drill down and view port-level information. On the switch faceplate, hover over a PoE port to view the following details:
  • Port
  • Name
  • Type
  • Class
  • Priority
From the Context drop-down list, select the context:
  • POE-STATUS—Displays the sate of each port. The state can be: Uplink, Drawing, Enabled, Disabled, or Alert.
  • POE-CLASS—Power class of the PoE port. The class can be: Class0, Class1, Class2, Class3, Class4, or Disabled.
  • POE PRIORITY—PoE priority configured on the port. The priority can be: Critical, High, or Low.
The following animation shows how to set the context on the faceplate:
Ports PoE
The Ports PoE table displays the following details:
  • Port—Port number.
  • Name—Name of the port.
  • PoE—PoE state: Enabled or Disabled.
  • Priority—PoE priority: Critical, High, or Low.
  • Status—Current power status of the PoE port: Searching, Delivering, Disabled, or Fault.
  • Pre-STD Detect—Displays whether PoE for pre-802.3af-standard powered devices is enabled on the switch: On or Off.
  • Alloc Actual—Power actually being used on the port.
  • Alloc Configured—The maximum amount of power allocated for the port.
  • PLC Class—Power class of the PoE port.
  • PLC Type—Physical layer classification type.
PoE Consumption
The PoE Consumption section displays a trend chart for the PoE power drawn from the Switch in watts. Hover your mouse over the trend chart to view the PoE power drawn at a particular time. For a stack, select the switch from the drop-down list to view the PoE consumption for the specific device.
The following animation shows how to view PoE consumption for a switch stack:
Viewing PoE Port-Level Information
Use one of the following options to navigate to the PoE port and view port-level information:
  • In the switch faceplate, click on the port number.
  • In the Ports PoE table, click the port number.
The following animation shows how to navigate to the PoE port level:
The port-level information page consists of the following tabs:
Summary
The Summary tab displays the following sections:
  • Summary—Displays the following details:
    • PSE Reserved Power—Power reserved for the port in the Power Sourcing Equipment (PSE).
    • PSE Voltage—Total voltage, in volts (V), currently being delivered to the powered device connected to the port
    • PD Power Draw—Power drawn by the powered device.
    • PD Amperage Draw—Amperage drawn by the powered device.
    • Over Current Count—Number of times a powered device connected to the port attempted to draw more power than was allocated to the port.
    • MPS Absent Count—Number of times the powered device has no longer requested power from the port MPS is Maintenance Power Signature.
    • Power Denied Count—Number of power requests from the port that were denied because sufficient power was unavailable.
    • Short Count—Number of times the switch provided insufficient current to the powered device connected to the port.
  • PoE Consumption—Displays the trend chart for PoE consumption and power available for the duration specified in the time range filter.
Slot Info & PoE Configuration
The Slot Info & PoE Configuration tab displays the following sections:
  • PoE Slot Information—Displays the following details:
    • Slot—Slot where the port is located.
    • Operation Status—Displays PoE power is available for the slot: On, Off, or Faulty.
    • Maximum Power—Maximum PoE wattage available to provision active PoE ports in the slot.
    • Power In Use—PoE power currently being used by the slot.
    • Usage Threshold—Configured percentage of available PoE power provisioning the switch must exceed to generate a usage notice.
  • PoE Configuration—Displays the following details:
    • PoE Power—Displays whether PoE power is enabled on the port.
    • Pre STD Detect—Displays whether PoE for pre-802.3af-standard powered devices is enabled on the switch: On or Off. This field is not displayed for AOS-CX switches.
    • PoE Port Status—Current power status of the PoE port: Searching, Delivering, Disabled, or Fault.
    • Power Priority—Power priority configured on ports enabled for PoE: Low, High, or Critical.
    • Allocate by Configuration—Maximum amount of power allocated for the port.
    • Allocate by Actual—Power actually being used on the port.
    • PLC Class Type—Physical layer classification type.
    • DLC Class Type—Data link layer classification type.
    • Configured Type—If configured, shows the user-specified identifier for the port. If not configured, this field is empty.
    • PoE Value configuration—PoE power value configured for the port. This field is not displayed for AOS-CX switches.
LLDP Information
The LLDP Information tab displays the following details:
  • UPSE Allocated Power—Power allocated for the port in the PSE.
  • PD Requested Power—Power requested by the powered device.
  • PD TLV Sent Type—TLV that is actually sent from the powered device.
  • PSE TLV Configured—TLV that is configured for the switch port to send to the powered device.
  • PSE TLV Sent Type—TLV that is actually sent from the PSE.
  • MED LLDP Detect—Status of the PoE LLDP detection. This field is not displayed for AOS-CX switches.
Actions
  • Reboot—Reboots the switch. See Rebooting Switches.
  • Tech Support—Allows the administrators to generate a tech support dump for troubleshooting the device. See Troubleshooting Aruba Switches.
  • Console—Opens the remote console for a CLI session through SSH. Ensure that you allow SSH over port 443. The default user ID is admin, but you can edit and customize the user ID. This custom user ID must be mapped to the device. See Opening Remote Console for Switch.
For AOS-CX 8320 and 8325 switch series, you must enable SSH server on the default VRF. Add the ssh server vrf default code to the template.
