Supported AOS-CX Switch Platforms
To manage your AOS-CX switches using Aruba Central, ensure that the switch software is upgraded to 10.05.0010 or a later version. AOS-CX switches with version 10.04.2000 or earlier might not connect to Aruba Central after ten days of operation. You must upgrade the AOS-CX switch to a recommended software version to connect to Aruba Central.
The following tables list the AOS-CX platforms, corresponding software versions supported in Aruba Central, and switch stacking details.
Switch Platform |
Supported Software Versions |
Recommended Software Versions |
Switch Stacking Support |
Supported Stack Type |
Maximum Number of Stack Members |
Supported Configuration Group Type (UI / Template) |
AOS-CX 6100 Switch Series
10.06.0110 or later |
10.06.0110 |
-N/A- |
-N/A- |
-N/A- |
Template |
AOS-CX 6200 Switch Series
10.05.0021 |
10.06.0101 |
Yes : 10.05.0021 |
VSF |
8 |
UI and Template |
AOS-CX 6300 Switch Series |
10.05.0021 |
10.06.0101 |
Yes : 10.05.0021 |
VSF |
10 |
UI and Template |
AOS-CX 6300 Switch Series [JL762A] Back 2 Front Power Supply SKUStock Keeping Unit. SKU refers to the product and service identification code for the products in the inventory. only |
10.06.0001 or later |
10.06.0101 |
Yes : 10.05.0021 |
VSF |
10 |
UI and Template |
AOS-CX 6405 Switch Series |
10.05.0021 |
10.06.0101 |
-N/A- |
-N/A- |
-N/A- |
Template only |
AOS-CX 6410 Switch Series |
10.05.0021 |
10.06.0101 |
-N/A- |
-N/A- |
-N/A- |
Template only |
AOS-CX 8320 Switch Series |
10.05.0021 |
10.06.0101 |
-N/A- |
-N/A- |
-N/A- |
UI and Template |
AOS-CX 8325 Switch Series |
10.05.0021 |
10.06.0101 |
-N/A- |
-N/A- |
-N/A- |
UI and Template |
AOS-CX 8360 Switch Series |
10.06.0101 |
-N/A- |
-N/A- |
-N/A- |
UI and Template |
AOS-CX 8400 Switch Series |
10.06.0001 |
10.06.0101 |
-N/A- |
-N/A- |
-N/A- |
Template only |
Provisioning and configuring of AOS-CX 6405, 6410, and 8400 switch series and switch stacks is supported only through configuration templates.
Data sheets and technical specifications for the supported switch platforms are available at: https://www.arubanetworks.com/products/networking/switches/.
