Configuring APs Using Templates
Templates in Aruba Central (on-premises) refer to a set of configuration commands that can be used by the administrators for provisioning devices in a group. Configuration templates enable administrators to apply a set of configuration parameters simultaneously to multiple devices in a group and thus automate access point (AP)  deployments.
To minimize configuration errors and troubleshoot device-specific configuration issues, Aruba recommends that the device administrators familiarize themselves with the CLI configuration commands available on Aruba APs.
For template-based provisioning, APs must be assigned to a group with template-based configuration method enabled.
To create a template for the APs in a template group, complete the following steps:
  1. In the Network Operations app, set the filter to one of the template group under Groups.
  2. Under Manage, click Devices > Access Points.
    A list of APs is displayed in the List view.
  3. Click the Config icon.
    The tabs to configure APs in a template group are displayed.
  4. In the Templates table, click + to add a new template.
    The Add Template window is displayed.
  5. Under Basic Info, enter the following information:
    1. Template Name—Enter the template name.
    2. Model—Set the model parameter to ALL.
    3. Version—Set the model parameter to ALL.
  6. Under Template, add the CLI script content.
  7. Check the following guidelines before adding content to the template:
    • Ensure that the command text indentation matches the indentation in the running configuration.
    • The template allows multiple per-ap-settings blocks. The template must include the per-ap-settings %_sys_lan_mac% variable. The per-ap-settings block uses the variables for each AP. The general VC configuration uses variables for conductor AP to generate the final configuration from the provided template. Hence, Aruba recommends that you upload all variables for all devices in a cluster and change values as required for individual AP variables.
    • You can obtain the list of variables for per-ap-settings by using the show amp-audit command.
      The following example shows the list of variables for per-ap-settings.
      (Instant AP)# show amp-audit | begin per-ap per-ap-settings 70:3a:0e:cc:ee:60 hostname EE:60-335-24 rf-zone bj-qa ip-address 10.65.127.24 255.255.255.0 10.65.127.1 10.65.6.15 "" swarm-mode standalone wifi0-mode access wifi1-mode access g-channel 6+ 21 a-channel 140 26 uplink-vlan 0 g-external-antenna 0 a-external-antenna 0 ap1x-peap-user peap22 282eaf1077b8d898b91ec41b5da19895
      The commands in the template are case-sensitive.
      IF ELSE ENDIF conditions are supported in the template. If the template text includes the if condition, % sign is required at the beginning and the end of the text. For example, %if guest%.
      The following example shows the template text with the IF ELSE ENDIF condition.
      Templates also support nesting of the IF ELSE END IF condition blocks.
      The following example shows how to nest such blocks:
      %if condition1=true% routing-profile route 10.10.0.0 255.255.255.0 10.10.0.255 %if condition2=true% routing-profile route 10.20.0.0 255.255.255.0 10.20.0.255 %else% routing-profile route 10.30.0.0 255.255.255.0 10.30.0.255 %endif% %else% routing-profile route 10.40.0.0 255.255.255.0 10.40.0.255 %if condition3=true% routing-profile route 10.50.0.0 255.255.255.0 10.50.0.255 %else% routing-profile route 10.60.0.0 255.255.255.0 10.60.0.255 %endif% %endif%
      For profile configuration CLI text, for example, vlanVirtual Local Area Network. In computer networking, a single Layer 2 network may be partitioned to create multiple distinct broadcast domains, which are mutually isolated so that packets can only pass between them through one or more routers; such a domain is referred to as a Virtual Local Area Network, Virtual LAN, or VLAN., interface, access-list, ssid and so on, the first command must start with no white space. The subsequent local commands in given profile must start with at least one initial space (' ') or indented as shown in the following examples:
      Example 1
      vlan 1 name "vlan1" no untagged 1-24 ip address dhcp-bootp exit
      Example 2
      %if vlan_id1% vlan %vlan_id1% %if vlan_id1=1% ip address dhcp-bootp %endif% no untagged %_sys_vlan_1_untag_command% exit %endif%
      To comment out a line in the template text, use the pound sign (#). Any template text preceded by # is ignored when processing the template.
      To allow or restrict APs from joining the Instant Access Point (IAP) cluster, Aruba Central uses the _sys_allowed_ap_ system-defined variable. Use this variable only when allowed APs configuration is enabled. For example, _sys_allowed_ap: "a_mac, b_mac, c_mac". Use this variable only once in the template.
  8. Click OK.
