Aruba Central Online Help
Access Point > Overview > AI Insights
In the access point (AP) dashboard, the
tab displays information on AP performance issues such as excessive channel changes, excessive reboots, airtime utilization, and memory utilization.Viewing Access Points > AI Insights
To navigate to the
tab in the AP dashboard, complete the following steps:-
In the
app, set the filter to one of the options under , , or . For all devices, set the filter to . Ensure that the filter selected contains at least one active AP.The dashboard context for the selected filter is displayed.
Under
, click > .A list of APs is displayed in the view. -
Click an AP listed under
.The dashboard context for the AP is displayed.
In the AP dashboard context, click the
tab.The
page is displayed. -
To exit the AP dashboard, click the back arrow on the filter.
You can change the time range for the
tab by clicking the time range filter and selecting one of the available options: , , , , and .AI Insights are displayed for the time range selected. Select the time range from the ) to filter reports.
AI Insights Categories
are categorized in high, medium, and low priorities depending on the number of occurrences.
Red—High priority
Orange—Medium priority
Yellow—Low priority
AI Insights listed in the dashboard are sorted from high priority to low priority. The The AI Insights Dashboard
dashboard displays a report of network events that could possibly affect the quality of the overall network performance. Each insight report provides specific details on the occurrences of these events for ease in debugging. For more information, seeThe
page displays the following insights:- Clients with High Wi-Fi Security Key-Exchange Failures
- Clients with High 802.1X Authentication Failures
- Clients with DHCP Server Connection Problems
- Clients with High Number of MAC Authentication Failures
- Clients with High Number of Wi-Fi Association Failures
- Clients with Captive Portal Authentication Problems
