About Tri-Radio Mode
Aruba Central (on-premises) offers tri-radio mode support in ArubaAP-555, a flagship 802.11ax access point (AP). In tri-radio mode or split 5 GHzGigahertz. mode, the 8x8 5 GHz radio is split into two independent 4x4 5 GHz radios. In the split 5 GHz Mode, Radio 5 GHz Secondary operates on channels from 36 to 64 and Radio 5 GHz operates on channels from 100 to 165.
To enable tri-radio, go to Access Points > Radio in the AP configuration dashboard, and select the Split Radio check-box.
The split 5 GHz radio can operate in the following modes:
  • Access
  • Monitor
  • Spectrum
Enabling Tri-Radio Mode
To enable the tri-radio mode, complete the following steps:
  1. In the Network Operations app, select one of the following options:
    • To select a group in the filter:
      1. Set the filter to one of the options under Groups. Ensure that the filter selected contains at least one active access point.
        The dashboard context for the group is displayed.
      2. Under Manage, click Devices > Access Points.
        A list of access points is displayed in the List view.
    • To select an access point in the filter:
      1. Set the filter to Global.
      3. Click an access point listed under Device Name.
        The dashboard context for the access point is displayed.
      4. Under Manage, click Devices > Access Point.
  2. Click the Config icon.
    The tabs to configure access points are displayed.
  3. Click the Access Points tab.
    The Access Points page is displayed.
  4. To edit an AP, select an AP in the Access Points table, and then click the edit icon.
  5. Click Radio.
  6. Select the Split Radio check-box.
  7. Click Save Settings.
Tri-Radio Events
To view the tri-radio events, complete the following steps:
    To select a group, label, site, or all devices in the filter, set the filter to one of the options under Groups, Labels, or Sites. For all devices, set the filter to Global.
    The dashboard context for the selected filter is displayed. To select a device in the filter:
    2. Under Manage, click Devices, and then click Access Points.
    3. A list of APs is displayed in the List view.
    4. Click an AP listed under Device Name.The dashboard context for the AP is displayed.
  2. Under Analyze, click Alerts & Events.The Alerts & Events page is displayed in the List view.
  3. Click the Events tab.
    A list of events is displayed in the Events table.
When the tri-radio mode is either enabled or disabled in an AP, the Events table displays the following details:
  • The Event Type column includes the AP Tri-Radio type which can be used to filter tri-radio events.
  • The Description column includes the status of the tri-radio mode in AP.
In Aruba Central (on-premises), the tri-radio feature is available only on AP-555 running Aruba Instant 8.6.0.0 or later versions.
By default, the AP-555 operates in dual radio mode.
