Access Point > Overview > Performance
In the access point (AP) dashboard, the Performance tab displays the size of data transmitted through the AP.
Viewing the Overview > Performance Tab
To navigate to the Performance tab in the AP dashboard, complete the following steps:
  1. In the Network Operations app, set the filter to one of the options under groups, labels, or sites. For all devices, set the filter to Global. Ensure that the filter selected contains at least one active AP.
  2. Under Manage, click Devices > Access Points.
    A list of APs is displayed in the List view.
  3. Click an AP listed under Device Name.
    The dashboard context for the AP is displayed.
  4. In the AP dashboard context, click the Performance tab. The Performance tab is displayed.
To exit the AP dashboard, click the back arrow on the filter.
You can change the time range for the Performance tab by clicking the time range filter and selecting one of the available options: 3 hours, 1 day, 1 week, 1 month, and 3 months.
The Performance tab provides the following details:
  • Throughput
    The Throughput graph indicates the size of data sent to and received by the device in bits per second for the wired or wireless networks. For example, Eth 0 or Eth 1 wired network profiles and specific SSIDsService Set Identifier. SSID is a name given to a WLAN and is used by the client to access a WLAN network. of wireless networks. You can also view data for all the wireless SSIDs by selecting All SSIDS from the drop-down list. You can view the overall data usage measured in bytes in the Overall Usage field.
  • Clients
    The Clients graph indicates the number of clients connected to the device for the wired, wireless, or radio network profiles for a selected time range in the time range filter. For example, wired for wired network profile, specific SSID or All SSIDs for wireless network profile, and 2.4 GHzGigahertz., 5 GHz, or 2.4 GHz&5 GHz for radio network profile. You can select a specific network profile from the drop-down list provided in the Clients section to view the date, time and number of clients connected.
When you hover over the Throughput and Clients graphs, it displays specific data for the selected timestamp.
Actions
The Actions drop-down list contains the following options:
Go Live
Aruba Central (on-premises) supports live monitoring of IAPs that support Aruba Instant 8.4.0.0 firmware version and above. Aruba Central (on-premises) allows you to monitor live data of an AP updated at every 5 seconds. For more information, see Enabling Live IAP Monitoring.
