RAPIDS
Aruba Central (on-premises) supports the rogue detection and classification feature that enables administrators to detect intrusion events and classify rogue devices. Rogue devices refer to the unauthorized devices in your WLANWireless Local Area Network. WLAN is a 802.11 standards-based LAN that the users access through a wireless connection. network. With RAPIDSRogue Access Point identification and Detection System. An AMP module that is designed to identify and locate wireless threats by making use of all of the information available from your existing infrastructure. , you can create a detailed defintion of what constitutes a rogue device, and act on an rogue or interfering devices that can be later considered for investigation, restrictive action, or both. Once the interfering devices are discovered, Aruba Central (on-premises) sends alerts to your network administrators about the possible threat and provides essential information needed to locate and manage the threat.
RAPIDS is not supported on single-node deployments.
Aruba Central (on-premises) supports the following features:
Viewing the RAPIDS Page
  1. In the Network Operations app, set the filter to one of the options under Groups, Labels, or Sites.
    For all devices, set the filter to Global.
  2. Under Manage, click Security > RAPIDS.
    By default, the IDS page with WIDS Events table is displayed.
  3. Click Rogues tab to view the rogues details page.
Monitoring IDS WIDS Events
The Manage> Security> RAPIDS > IDSIntrusion Detection System. IDS monitors a network or systems for malicious activity or policy violations and reports its findings to the management system deployed in the network. tab provides a summary of the total number of wireless attacks detected for a given duration.
The WIDSWireless Intrusion Detection System. WIDS is an application that detects the attacks on a wireless network or wireless system. Events table displays the following information category:
  • Infrastructure attacks—Displays the number of infrastructure attacks detected in the network.
  • Client attacks—Displays the number of client attacks detected in the network.
Viewing the IDS Page
Table 1: WIDS Events
Field
Description
Event Type
The type of the intrusion or attack detected. Click the drop-down arrow at the column heading to filter the event types based on your requirement.
Category
Category of the intrusion or attack, infrastructure, or client attack. Click the drop-down arrow at the column heading to filter the category that you want to display.
Level
The level of the intrusion or attack detected. Click the drop-down arrow at the column heading to filter the attack level.
Time
Time of the intrusion or attack.
Station MAC
MAC address of the station under attack or BSSIDBasic Service Set Identifier. The BSSID identifies a particular BSS within an area. In infrastructure BSS networks, the BSSID is the MAC address of the AP. In independent BSS or ad hoc networks, the BSSID is generated randomly. of the AP under attack.
Detecting AP
The MAC address of the device that detected the intrusion or attack.
Radio Band
Radio bandBand refers to a specified range of frequencies of electromagnetic radiation. on which the intrusion was detected. There are two radio band signals available, 2.4 GHZ and 5 GHZ. Click the drop-down arrow at the column heading to filter the radio band where the intrusion was detected.
Description
Details of the attack or the intrusion.
Note the following important points:
  • Clicking icon enables you to customize the WIDS Events table or set it to the default view.
  • To view the details of each event that is generated, click the arrow against each row in the table.
  • Intrusions are displayed for the time selected in Time Range Filter. The WIDS Events displayed data for a maximum time period of 1 week only.
Monitoring Rogues
The Rogues tab provides a summary of the rogue APs, suspected rogue APs, interfering APs, and neighboring APs, and the total number of wireless attacks detected for a given duration.
Viewing the Rogues Page
  2. Under Manage, click Security.
    By default, the RAPIDS > IDS tab is displayed.
  3. Click Rogues tab to view the page.
The APs in Aruba Central (on-premises) are classified as one of the following:
Table 2: AP Classification in Aruba Central (on-premises)
Classification
Description
Rogue AP
An unauthorized AP plugged into the wired side of the network.
Suspect Rogue AP
An unauthorized access point with a signal strength greater or equal to -75 dBmDecibel-Milliwatts. dBm is a logarithmic measurement (integer) that is typically used in place of mW to represent receive-power level. AMP normalizes all signals to dBm, so that it is easy to evaluate performance between various vendors. that might have connected to the wired network.
Interfering AP
An AP detected in the RFRadio Frequency. RF refers to the electromagnetic wave frequencies within a range of 3 kHz to 300 GHz, including the frequencies used for communications or Radar signals. environment with a signal strength lesser than -75 dBm but not connected to the wired network. These access points may potentially cause RF interference, but cannot be considered as a direct security threat as these devices are not connected to the wired network. For example, an interfering AP can be an access point that belongs to a neighboring office’s WLAN but is not part of your WLAN network.
Neighbor AP
A neighboring AP, foe which the BSSIDs are known. Once classified, a neighboring AP does not change its state.
The Security > RAPIDS > Rogues page displays the following information tabs:
  • Total—Shows the total number of rogues classified as Rogue , Suspected Rogue, or Interfering, that are detected in the network.
  • Rogues—Shows the total number of devices classified as rogue APs.
  • Suspected Rogues—Shows the total number of devices classified as suspected rogues APs.
  • Interfering—Shows the total number of devices classified as interfering APs.
  • Neighbors—Shows the total number of devices classified as neighbor APs.
  • Click the respective tabs to display specific rogue information pertaining to each classification. By default, the Total information tab is selected and the Detected Access Points table displays all the detected rogue APs.
Table 3: Rogues
Fields
Description
BSSID
The BSSIDs broadcast by the rogue device.
Name
Name of the rogue device detected in the network.
Classification
Classification of the rogue device (monitored device) as Suspect Rogue, or Interferer. Click the drop-down arrow at the column heading to filter the rogue classification that you want to display.
SSID
The SSIDService Set Identifier. SSID is a name given to a WLAN and is used by the client to access a WLAN network. broadcast by the rogue device.
Last Seen
The time relative to the current moment, for example, 6 minutes or an hour, at which the rogue device was last detected in the network.
Last Seen By
The AP name of the last device that reported the monitored AP.
First Seen
The time relative to the current moment (for example, 6 minutes or an hour) at which the rogue device was first detected in the network.
Signal
The signal strength of the AP that detected the rogue device.
Encryption
The type of encryption used by the device that detected the rogue device; for example, WPAWi-Fi Protected Access. WPA is an interoperable wireless security specification subset of the IEEE 802.11 standard. This standard provides authentication capabilities and uses TKIP for data encryption., Open, WEPWired Equivalent Privacy. WEP is a security protocol that is specified in 802.11b and is designed to provide a WLAN with a level of security and privacy comparable to what is usually expected of a wired LAN. , Unknown. Generally, this field alone does not provide enough information to determine if a device is a rogue device, but it is a useful attribute. If a rogue is not running any encryption method, that implies you have a wider security hole than with an AP that is using encryption.
Containment Status
Details of the containment status. Click the drop-down arrow at the column heading to filter the status that you want to display.
MAC Vendor
The vendor name associated to the MAC OUIOrganizationally Unique Identifier. Synonymous with company ID or vendor ID, an OUI is a 24-bit, globally unique assigned number, referenced by various standards. The first half of a MAC address is OUI. of the rogue device.
  • VisualRF uses the heard signal information to calculate the physical location of the device.
  • Click to customize the Detected Access Points table columns or set it to the default view.
  • To view details of each rogue device, click the arrow against each row in the table.
  • Rogue devices are displayed for the time selected in Time Range Filter. The Detected Access Points displays data for a maximum time period of 1 week only.
Configuring IDS Parameters
The type and severity of Intrusion Detections raised by an AP is configurable and affects the data that is seen in Security. For more information on how to configure IDS Parameters, see Configuring IDS Parameters on APs.
Generating Alerts for Security Events
Aruba Central (on-premises) supports configuring alerts for rogue AP detections and IDS events. To generate alerts, complete the following steps:
  1. In the Network Operations app, use the filter to select Global.
  2. Under Analyze, click Alerts & Events. The Alerts & Events page is displayed.
  3. In the Alerts & Events page, click the Config icon.
    The Alert Severities & Notifications page is displayed.
  4. Select Access Point to display the AP dashboard. Aruba Central (on-premises) supports three alert types for identifying interfering devices:
    • Rogue AP Detected
    • Infrastructure Attacks Detected
    • Client Attack Detected
  5. Select an alert and click + to enable the alert with default settings. To configure alert parameters, click on the alert tile (anywhere within the rectangular box) and do the following:
    1. Severity—Set the severity. The available options are Critical, Major, Minor, and Warning.
    2. Device Filter Options—(Optional) You can restrict the scope of an alert by setting one or more of the following parameters:
      For a few alerts, you can configure threshold value for one or more alert severities. To set the threshold value, select the alert and in the exceeds text box, enter the value. The alert is triggered when one of the threshold values exceed the duration.
      • Label—Select a label to limit the alert to a specific label.
      • Sites—Select a site to limit the alert to a specific site.
    3. Notification Options
      • Email—Select the Email check box and enter an email address to receive notifications when an alert is generated. You can enter multiple email addresses, separate each value with a comma.
      • Streaming—Select the Streaming check box to receive the streaming notifications when an alert is generated.
      • Webhook—Select the Webhook check box and select the Webhook from the drop-down list. For more information, see Aruba Central Help Center.
      • Syslog—Select the Syslog checkbox to receive the syslog notifications when an alert is generated.
    4. Click Save.
    5. Add Rule—(Optional) For a few alerts, the Add Rule option appears. For such alerts, you can add additional rule(s). The rule summaries appear at the top of the page.
    For more information on how to configure Alerts, see Configuring Alerts.
Generating Reports for Security Events
Aruba Central (on-premises) supports generating reports for rogue AP detections and IDS events. To generate reports, complete the following steps:
  2. Under Analyze, click Reports.
  3. In the Reports page, click Create. Aruba Central (on-premises) supports RAPIDS to display the report of all wireless intrusions. For more information on how to create Reports, see Creating a Report.
