Configuring Logging Servers for AOS-CX
Logging allows you to add syslog servers where the event log messages related to the AOS-CX switches are saved. For each of the syslog server you add, you can configure the severity of the event logs to be saved on these servers. You can also configure the severity level for the debug logs by configuring the severity at the global level. However, you must add a minimum of one syslog server to configure the global severity level.
To configure logging servers, complete the following steps:
  1. In the Network Operations app, select one of the following options:
    • To select a group in the filter:
      1. Set the filter to a group.
        The dashboard context for the group is displayed.
      3. Click the AOS-CX or Config icon to view the AOS-CX switch configuration dashboard.
    • To select a switch:
      1. Set the filter to Global or a group containing at least one switch.
      3. Click an AOS-CX switch under Device Name.
        The dashboard context for the switch is displayed.
      4. Under Manage, click Device.
        The AOS-CX UI configuration page is displayed.
  2. Click System > Logging.
    The Logging page is displayed.
  3. Select the debug syslog severity level at the global level from the Level drop-down.
    This severity level is applied to the debug logs that are saved on the syslog servers. You must add a minimum of one event syslog server before configuring the global severity level.
  4. In the Logging Servers table, click the + add icon to add a logging server and configure the following parameters in the Add Logging Server page:
    Table 1: Logging Server Parameters
    Parameters
    Description
    Value
    FQDN or IP address
    FQDNFully Qualified Domain Name. FQDN is a complete domain name that identifies a computer or host on the Internet. hostname or IP address of the logging server.
    IPv4 address in the x.x.x.x format or hostname of the server.
    Level
    Severity level of the events that the logging server must log.
    Following severity levels are supported:
    • Emergency
    • Critical
    • Alert
    • Error
    • Warning
    • Notice
    • Information
    • Debug
    VRF
    VRFVisualRF. VRF is an AirWave Management Platform (AMP) module that provides a real-time, network-wide views of your entire Radio Frequency environment along with floor plan editing capabilities. VRF also includes overlays on client health to help diagnose issues related to clients, floor plan, or a specific location. on which the logging server is configured.
    Default or Management.
    NOTE: Management VRF is not supported on the AOS-CX 4100i and 6100 switch series.
  5. Click Apply and then click Save.
  6. To edit parameters of a logging server, select the row in the Logging Servers table and click the edit icon.
    The Edit Logging Server page is displayed. You can edit only the event log severity level and the VRF.
  7. Click Apply and then click Save.
  8. To delete the syslog server, select the row in the Logging Servers table and click the delete icon.
  9. Click OK in the confirmation pop-up and then click Save.
