Configuring SNMPv2c on AOS-CX
You can configure SNMPv2cCommunity-Based Simple Network Management Protocol version 2. SNMPv2C uses the community-based security scheme of SNMPv1 and does not include the SNMPv2 security model. community settings and trap destinations through the UI.
To configure SNMPv2c on switch, complete the following steps:
- In the app, select one of the following options:
- To select a switch group in the filter:
- Set the filter to a group.
The dashboard context for the group is displayed.
- Under , click > .
- Click the or Config icon to view the switch configuration dashboard.
- To select a switch in the filter:
- Set the filter to or a group containing at least one switch.
- Under , click > .
A list of switches is displayed in the view.
- Click an AOS-CX switch under .
The dashboard context for the switch is displayed.
- Under , click .
The AOS-CX UI configuration page is displayed.
- Click > .
- Enable SNMP on the switch by moving the SNMP toggle to the on position.
- Select the VRFVisualRF. VRF is an AirWave Management Platform (AMP) module that provides a real-time, network-wide views of your entire Radio Frequency environment along with floor plan editing capabilities. VRF also includes overlays on client health to help diagnose issues related to clients, floor plan, or a specific location. on which you want to configure SNMP by selecting one or both of the following check boxes under Enable SNMP on the selected VRF:
- Default VRF
- Management VRF
Management VRF is not supported on the AOS-CX 4100i and 6100 switch series.
- Select from the drop-down.
The and tables are displayed.
Adding an SNMP Community
You can add SNMP communities to restrict access to the switch from the SNMP management stations. The default community name is Public.
To add an SNMP community, complete the following steps:
- In the table, click . A new row is added in the table.
- Type the name of the community in the new row. You can enter up to a maximum of 32 characters including letters, numbers, and special characters.
- Click .
Editing an SNMP community
To edit an SNMP community, point to the row for the SNMP community, and click the edit icon.
You can edit an SNMP community name only before saving it to Aruba Central (on-premises). If the SNMP community is saved, then it cannot be edited.
Deleting an SNMP Community
To delete an SNMP community, point to the row for the SNMP community, and click the delete icon.
If you delete an SNMP community, trap destinations that belong to the community will also get deleted.
Adding a Trap Destination
You can add trap destinations to send notifications to SNMP management stations.
When adding a trap destination, you cannot edit the SNMP toggle switch and the Enable SNMP on the selected VRF options.
To add a trap destination, complete the following steps:
- In the table, click the . A new row is added in the table.
- Configure the following parameters:
- —Enter a valid IPv4 or IPv6 address of the SNMP host.
- —Select the available VRF on the switch from the drop-down.
- —Select the name of the community from the drop-down.
- Click .
Editing a Trap Destination
To edit a trap destination, point to the row for the trap destination, and click the edit icon.
You can edit only the community name.
Deleting a Trap Destination
To delete a trap destination, point to the row for the trap destination, and click the delete icon.
