Configuring SNMPv3 on AOS-CX
SNMPv3Simple Network Management Protocol version 3. SNMPv3 is an enhanced version of SNMP that includes security and remote configuration features. provides a secured access to SNMPSimple Network Management Protocol. SNMP is a TCP/IP standard protocol for managing devices on IP networks. Devices that typically support SNMP include routers, switches, servers, workstations, printers, modem racks, and more. It is used mostly in network management systems to monitor network-attached devices for conditions that warrant administrative attention. management stations using authentication and privacy protocols. You can add SNMPv3 user and configure notification settings using UI groups.
To configure SNMPv3 on switch, complete the following steps:
- In the app, select one of the following options:
- To select a switch group in the filter:
- Set the filter to a group containing at least one switch.
The dashboard context for the group is displayed.
- Under , click > .
- Click the icon to view the switch configuration dashboard.
- To select a switch in the filter:
- Set the filter to or a group containing at least one switch.
- Under , click > .
A list of switches is displayed in the view.
- Click a switch under .
The dashboard context for the switch is displayed.
- Under , click .
The tabs to configure the switch is displayed.
- Click > .
The SNMP page is displayed.
- Enable SNMP service on the switch by moving the SNMP toggle to the on position.
Select the VRFVisualRF. VRF is an AirWave Management Platform (AMP) module that provides a real-time, network-wide views of your entire Radio Frequency environment along with floor plan editing capabilities. VRF also includes overlays on client health to help diagnose issues related to clients, floor plan, or a specific location. on which you want to configure SNMP by selecting one or both of the following check boxes under Enable SNMP on the selected VRF:
- Default VRF
- Management VRF
Management VRF is not supported on the AOS-CX 4100i and 6100 switch series.
- Select from the drop-down.
The and Ttables are displayed.
Adding an SNMPv3 User
You can add SNMPv3 users to provide secured access to SNMP management stations.
To add an SNMPv3 user, complete the following steps:
- In the table, click . A new row is added in the table.
- Configure the following parameters:
- —Enter the name of the SNMPv3 user.
- —Select either (Message Digest) or (Secure Hash Algorithm) as the authentication mode to provide secured access to the user. After selecting the authentication mode, enter the authentication password. The password must be 8 to 32 characters long, and can contain alphabets, numbers, and special characters.
- —Select (Advanced Encryption Standard) or (Data Encryption Standard) as the privacy mode to provide secured access to the user. After selecting the privacy mode, enter the privacy password. The password must be 8 to 32 characters long, and can contain alphabets, numbers, and special characters.
- Click .
Editing an SNMPv3 User
To edit an SNMPv3 user, point to the row for the user, and click the edit icon.
You can edit an SNMPv3 user only before saving it to Aruba Central (on-premises). If the user is saved to Aruba Central (on-premises), then it cannot be edited.
Deleting an SNMPv3 User
To delete an SNMPv3 user, point to the row for the user, and click the delete icon.
If you delete the user, then the trap destination where the user is added will also get deleted.
Adding a Trap Destination
You can add trap destinations to send notifications to SNMP management stations.
When adding a trap destination, you cannot edit the SNMP toggle switch and the Enable SNMP on the selected VRF options.
To add a trap destination, complete the following steps:
- —Enter a valid IPv4 or IPv6 address of the SNMP host.
- —Select the available VRF on the switch from the drop-down.
- —Select the user to whom the notifications should be sent.
- Click .
Editing a Trap Destination
To edit a trap destination, point to the row for the trap destination, and click the edit icon.
You can only edit the user name.
Deleting a Trap Destination
To delete a trap destination, point to the row for the trap destination, and click the delete icon.
