Configuring Source Interface for AOS-CX
Source interface allows you to configure a single source interface for a service so that all traffic routed through the switch is sent with the same IP address. The IP address is configured on the ports, LAGs, or VLANsVirtual Local Area Network. In computer networking, a single Layer 2 network may be partitioned to create multiple distinct broadcast domains, which are mutually isolated so that packets can only pass between them through one or more routers; such a domain is referred to as a Virtual Local Area Network, Virtual LAN, or VLAN. at the device level.
You can add, modify, or delete source interface configuration in Aruba Central (on-premises). At the group level, Aruba Central (on-premises) allows you to configure only the port or LAGLink Aggregation Group . A LAG combines a number of physical ports together to make a single high-bandwidth data path. LAGs can connect two switches to provide a higher-bandwidth connection to a public network. information for the interface. However, at the device level, you can also configure VLANs and IP address for the interface.
Aruba Central (on-premises) supports only Central and User-based tunneling source interfaces in the UI. However, in the MultiEdit mode, you can configure source interfaces for other protocols such as, DNSDomain Name System. A DNS server functions as a phone book for the intranet and Internet users. It converts human-readable computer host names into IP addresses and IP addresses into host names. It stores several records for a domain name such as an address 'A' record, name server (NS), and mail exchanger (MX) records. The Address 'A' record is the most important record that is stored in a DNS server, because it provides the required IP address for a network peripheral or element., NTPNetwork Time Protocol. NTP is a protocol for synchronizing the clocks of computers over a network., and PTP. The source interfaces that you add in the MultiEdit mode (other than Central and User-based tunneling) will not appear in the Source Interface page at the device level.
When you downgrade a switch from AOS-CX 10.07.0020 (with Central as source interface) to an earlier firmware version where source interface is not supported, Aruba Central does not allow the configuration to sync and displays a configuration conflict.
In such instances, you must delete the conflicting source interface configuration for Aruba Central to sync the configuration.
Switch Platform |
Supported Source Interfaces |
10.05, 10.06 |
10.07 |
10.08 |
AOS-CX 4100i Switch Series |
-N/A- |
-N/A- |
AOS-CX 6100 Switch Series |
-N/A- |
-N/A- |
AOS-CX 6200 Switch Series
-N/A- |
AOS-CX 6300 Switch Series |
User-based tunneling only |
Central and User-based tunneling |
-N/A- |
AOS-CX 8320 Switch Series |
-N/A- |
Central only |
-N/A- |
AOS-CX 8325 Switch Series |
-N/A- |
Central only |
-N/A- |
AOS-CX 8360 Switch Series |
-N/A- |
Central only |
-N/A- |
To add a source interface, you must configure the following at the device level:
- Enable routing for ports and LAGs.
- Configure an IP address for the ports, LAGs, and VLANs.
Adding a Source Interface
To add a source interface, complete the following steps:
- In the app, select one of the following options:
- To select a switch group in the filter:
- Set the filter to a group.
The dashboard context for the group is displayed.
- Under , click > .
- Click the icon to view the switch configuration dashboard.
- To select a switch in the filter:
- Set the filter to or a group containing at least one switch.
- Under , click > .
A list of switches is displayed in the view.
- Click an AOS-CX switch under .
The dashboard context for the switch is displayed.
- Under , click .
The AOS-CX UI configuration page is displayed.
- Click > .
The Source Interface page is displayed with a list of source interfaces that are configured.
- In the table, click the + add icon to add a source interface and configure the following parameters in the Create Source Interface page.
When both Central and User-based tunneling source interfaces are added for a switch, the + add icon is disabled.
Table 2: Configuring and Viewing Source Interface Parameters
Name
Description
Value
The interface or the service name.
You can configure only two interfaces at any given time.
Central or User-based tunneling
Type of interface you want to configure.
The name of this field is applicable only at the group level.
At the device level, the field name is Port/LAG/VLAN/Address.
- At the group level—Port or LAG
- At the device level—Port, LAG, VLAN, or Address
Port name
Port number for the source interface.
Applicable when you select Port in the Port/LAG drop-down at the group level or Port/LAG/VLAN/Address drop-down at the device level.
Select a port from the drop-down.
- At the group level—Only the ports that have routing enabled at the group level are available in this drop-down.
- At the device level—Only the ports that have routing enabled and IP address configured on the ports at the device level are listed in this drop-down.
LAG name
LAG name for the source interface.
Select a LAG from the drop-down.
- At the group level—Only the LAGs that have routing enabled at the group level are available in this drop-down.
- At the device level—Only the LAGs that have routing enabled and IP address configured on the LAGs at the device level are listed in this drop-down.
VLAN ID
VLAN ID for the source interface.
- Available only at the device level.
- Applicable when you select VLAN in the Port/LAG/VLAN/Address drop-down at the device level.
Select a VLAN from the drop-down.
- Only the VLANs that have an IP address configured at the device level are listed in this drop-down.
- The IP address must be a static IP address. DHCPDynamic Host Configuration Protocol. A network protocol that enables a server to automatically assign an IP address to an IP-enabled device from a defined range of numbers configured for a given network. server is not supported.
Address
IP address for the source interface.
- Applicable when you select Address in the Port/LAG/VLAN/Address drop-down at the device level.
IPv4 address
Type of VRF for the source interface.
You can configure the User-based tunneling interface only on the Default VRF.
Default or Management
Management VRF is not supported on the AOS-CX 4100i and 6100 switch series.
- Click .
The source interface information is displayed in the Source Interface table.
Editing a source interface
To edit a source interface, point to the row for the source interface, and click the
edit icon. You can select only one source interface at a time for editing.
- When editing the Central interface, you cannot edit the interface type.
- When editing the User-based tunneling interface, you cannot edit the interface type and the VRF.
Deleting a source interface
To delete a source interface, point to the row for the source interface, and click the
delete icon. Deleting source interface at device level and modifying configuration at group level will not add the source interface again on the device. You can select only one source interface at a time for deleting.
Deleting the user-based tunneling source interface disables all configurations that depend on this source interface, for example, Dynamic Segmentation, Client Roles.
