Configuring VLANs on AOS-CX
VLANsVirtual Local Area Network. In computer networking, a single Layer 2 network may be partitioned to create multiple distinct broadcast domains, which are mutually isolated so that packets can only pass between them through one or more routers; such a domain is referred to as a Virtual Local Area Network, Virtual LAN, or VLAN. are primarily used to provide network segmentation at layer 2. VLANs enable the grouping of users by logical function instead of physical location. VLANs make managing bandwidth usage within networks possible by:
- Allowing grouping of high-bandwidth users on low-traffic segments
- Organizing users from different LANLocal Area Network. A LAN is a network of connected devices within a distinct geographic area such as an office or a commercial establishment and share a common communications line or wireless link to a server. segments according to their need for common resources and individual protocols
- Improving traffic control at the edge of networks by separating traffic of different protocol types
- Enhancing network security by creating subnetsSubnet is the logical division of an IP network. to control in-band access to specific network resources
From VLANs page, you can add VLANs and manage VLAN settings such as name, description, admin status, and IP assignment for AOS-CX switches.
For AOS-CX 6200 and 6300 switch series, VLAN 1 (DEFAULT_VLAN_1) is associated with all interfaces on the switch. The DHCPDynamic Host Configuration Protocol. A network protocol that enables a server to automatically assign an IP address to an IP-enabled device from a defined range of numbers configured for a given network. assignment of IP address is available only on the default VLAN.
You can add only one VLAN at a time.
Adding a VLAN
To add a VLAN, complete the following steps:
- In the app, select one of the following options:
- To select a switch group in the filter:
- Set the filter to a group.
The dashboard context for the group is displayed.
- Under , click > .
- Click the or icon to view the switch configuration dashboard.
- To select a switch in the filter:
- Set the filter to or a group containing at least one switch.
- Under , click > .
A list of switches is displayed in the view.
- Click an AOS-CX switch under .
The dashboard context for the switch is displayed.
- Under , click .
The AOS-CX UI configuration page is displayed.
- Click > .
The VLANs page is displayed with a list of VLANs.
- In the table, click the + add icon to add a VLAN and configure the following parameters.
When the maximum number of VLANs are added for a switch, the + add icon is disabled.
Table 1: Configuring and Viewing VLAN Parameters
Name
Description
Value
The VLAN ID number.
Following are the different ranges for the VLANs supported on switches:
- AOS-CX 4100i, 6100 switch series—2 to 512
- AOS-CX 6200 switch series—2 to 2048
- AOS-CX 6300 and 8360 switch series—2 to 4094
- AOS-CX 8320 and 8325 switch series—2 to 4040
At the group level, the maximum VLANs supported is 4094
AOS-CX 6400 and 8400 switch series are not supported in Aruba Central (on-premises) UI configuration.
The name of the VLAN.
Only letters (a-z) and numbers (0-9) are allowed.
The description of the VLAN.
Letters, numbers, and special characters are allowed except question mark (?) and double quotes (").
The operational status of the VLAN. The VLAN can forward packets only when the check box is selected.
Select the check box to enable.
The VLAN support for voice.
The method of IP assignment. The options to enter the IP address is displayed only when you select . This field is available only at the device level.
The DHCP option is available only for the default VLAN on AOS-CX 6100, 6200, and 6300 switch series.
, , or
Default:
The IP address with subnet mask for IP assignment.
This field is enabled only when you select from the drop-down and available only at the device level.
IPv4 address or IPv6 address with subnet mask
Format: (x.x.x.x/x).
The IP address of the DHCP relay server. This field is enabled only when you select or from the drop-down and available only at the device level.
- AOS-CX 6100 and 6200 switch series—DHCP relay is not supported
- AOS-CX 6300 switch series—DHCP relay is available only on the default VLAN
IPv4 address
- Click .
The VLAN information is displayed in the VLANs table.
Editing a VLAN
To edit a VLAN, point to the row for the VLAN, and click the edit icon. You can select only one VLAN at a time for editing.
You cannot edit the name of the default VLAN and admin status.
Deleting a VLAN
To delete a VLAN, point to the row for the VLAN, and click the delete icon. Deleting VLAN at device level and modifying configuration at group level will not add the VLAN again on the device. You can select only one VLAN at a time for deleting.
You cannot delete the default VLAN.
