Switch > VSX
Aruba Virtual Switching Extension (VSX) is virtualization technology for aggregation and core AOS-CX switches. The VSX solution lets the switches present as one virtualized switch in critical areas.
VSX is supported in the AOS-CX 6400, AOS-CX 8320, and AOS-CX 8325 Switch Series.
Aruba Central (on-premises) provides support for VSX by displaying information about the configurations of the switches and the status of the inter-switch link (ISL) between the switches.
Viewing the VSX Page
To navigate to the VSX page in the Switch dashboard, complete the following steps:
- In the app, set the filter to one of the options under , , or . Ensure that the filter selection contains at least one AOS-CX switch. For all devices, set the filter to .
- Under , click > .
A list of switches is displayed in the view.
- Click an AOS-CX switch under .
The dashboard context for the switch is displayed.
- Under , click .
The page displays the following details:
- To exit the switch dashboard, click the back arrow on the filter.
VSX Summary
Displays state information of the switch, connections to the peer switch, and the role of the switch in the VSX configuration.
Field |
Description |
State of the ISL connection with the peer AOS-CX switch. Following are the supported values:
Management state of the ISL. Following are the supported values:
Status of the configuration synchronization between the VSX switches. Following are the supported values:
Status of the NAE connection between the VSX switches. |
Status of the HTTPSHypertext Transfer Protocol Secure. HTTPS is a variant of the HTTP that adds a layer of security on the data in transit through a secure socket layer or transport layer security protocol connection. server connection between the VSX switches. |
Timestamp of when the configuration was synched between the peer switch. Last synced data is displayed in the Switch > VSX page only when VSX synchronization is enabled for the AOS-CX switch. However, enabling VSX synchronization using template configuration in Aruba Central (on-premises) is not recommended. By enabling VSX synchronization, the peer switch may get into an unknown configuration state. |
Role of the AOS-CX switch in the VSX configuration. Supported values are and |
Info
Displays system and configuration information of the switch and its peer. The following details are displayed:
- —MACMedia Access Control. A MAC address is a unique identifier assigned to network interfaces for communications on a network. address of the selected switch.
- —MAC address of the peer switch.
- —Hostname of the peer switch.
- —IPv4 address of the peer switch.
- —Indicates whether the configuration synchronization between the peers are enabled or disabled.
- —Inter-switch Link (ISL) port number of the selected AOS-CX switch. If the ISL is a LAGLink Aggregation Group . A LAG combines a number of physical ports together to make a single high-bandwidth data path. LAGs can connect two switches to provide a higher-bandwidth connection to a public network. , then this field displays the LAG name.
- —ISL port number of the peer switch. If the ISL is a LAG, then this field displays the LAG name.
- —List of MC LAG names present in the switches.
Actions
The tab displays the various options available for remote administration of the switch. The following options are available:
- —Reboots the switch. See Rebooting Switches.
- —Allows the administrators to generate a tech support dump for troubleshooting the device. See Troubleshooting Aruba Switches.
- —Opens the remote console for a CLI session through SSHSecure Shell. SSH is a network protocol that provides secure access to a remote device. . Ensure that you allow SSH over port 443. The default user ID is admin, but you can edit and customize the user ID. This custom user ID must be mapped to the device. See Opening Remote Console for Switch.
For AOS-CX 8320 and 8325 switch series, you must enable SSH server on the default VRFVisualRF. VRF is an AirWave Management Platform (AMP) module that provides a real-time, network-wide views of your entire Radio Frequency environment along with floor plan editing capabilities. VRF also includes overlays on client health to help diagnose issues related to clients, floor plan, or a specific location.. Add the ssh server vrf default code to the template.
