Aruba Central Online Help
Removing a Stack Using Template
You can remove a stack member using the template. It involves completing procedures both in Aruba Central (on-premises) and on the switch directly.
To remove a stack using the template, complete the following steps:
- In Aruba Central (on-premises), set the to in the page.
- Shut down all the members in the stack.
- Remove all the physical VSF links from the members of the stack.
- Run the erase all zeroize command on the switch CLI for all the switches in the stack. This causes the switches to reboot, rollback to factory defaults, and connect back to Aruba Central (on-premises) as standalone devices.
- In Aruba Central (on-premises), set the to in the page. Once the configuration is pushed, the stack will be removed from Aruba Central (on-premises).
