Aruba Central Online Help
Changing the Standby Conductor Using Template
To change the standby conductor using the template, update vsf secondary-member <ID> line in the Aruba Central (on-premises) template. For example, if you want to change the standby conductor from member 2 to member 3 in the stack, update member ID in the line from vsf secondary-member 2 to vsf secondary-member 3 and save the template. Both the existing standby conductor and the new standby conductor are rebooted. After rebooting, member 3 joins the stack as the new standby conductor. The earlier standby conductor becomes a member of the stack.
