Aruba Central Online Help
Modifying VSF Links Using Template
You can modify VSF links through the template only when the VSF interfaces of all the switches in the stack are in the shutdown state.
To modify VSF links using the template, complete the following steps:
- In the Aruba Central (on-premises) template, use a variable to hold the shutdown state of the VSF interfaces for all switches in the stack.
- Push the template with the interfaces state variables changed to shutdown for the device and wait for the links to go down.
- Change the links in the template as required.
- Change the state to
no shutdownin the template variable for the switches in the stack and save the template.
