Configuring DHCP Snooping on AOS-Switches
When you enable DHCP snoopingDHCP snooping enables the switch to monitor and control DHCP messages received from untrusted devices that are connected to the switch., DHCP packets received at untrusted ports will be dropped, because all ports are configured as untrusted by default. You must configure the ports to be trusted in the > > page.
You must also configure authorized DHCP servers for the network to have a functional DHCP server that serves clients on this switch.
By default, DHCP snooping is disabled for the switch.
Enabling DHCP Snooping on a Switch
To enable DHCP snooping on a switch, complete the following steps:
- In the app, select one of the following options:
- To select a switch group in the filter:
- Set the filter to a group containing at least one switch.
The dashboard context for the group is displayed.
- Under , click > .
- Click the AOS-S or icon to view the switch configuration dashboard.
- To select a switch in the filter:
- Set the filter to or a group containing at least one switch.
- Under , click > .
A list of switches is displayed in the view.
- Click a switch under .
The dashboard context for the switch is displayed.
- Under , click .
The tabs to configure the switch is displayed.
- Click > . The DHCP Snooping page is displayed.
- To enable DHCP snooping for the switch, move the toggle switch to the on position.
- To enable option-82 for the switch, move the toggle switch to the on position.
- When you enable both DHCP snooping and option-82, the switch drops the option-82 information from the DHCP packets.
- Click .
Adding Authorized DHCP Servers for a Switch
To add the list of IP addresses of authorized DHCP servers for a switch, complete the following steps:
- In the page, click + in the table. The Add Authorized DHCP Server IP window is displayed.
- Enter the IP address in the field.
- Click .
- Click .
Deleting Authorized DHCP Servers for a Switch
To delete the authorized DHCP servers IP addresses, in the table, point to IP address, and click the delete icon for the DHCP server IP you want to delete.
Enabling DHCP Snooping for a VLAN
To enable DHCP snooping for a VLANVirtual Local Area Network. In computer networking, a single Layer 2 network may be partitioned to create multiple distinct broadcast domains, which are mutually isolated so that packets can only pass between them through one or more routers; such a domain is referred to as a Virtual Local Area Network, Virtual LAN, or VLAN., complete the following steps:
- In the table, select the VLAN row(s) for which you want to configure DHCP snooping, and click .
- Select or from the drop-down.
- Click .
- Click .
