Configuring IGMP on AOS-Switches
By default, IGMP is disabled for all VLANs.
To enable IGMP for a VLAN, complete the following steps:
- In the app, select one of the following options:
- To select a switch group in the filter:
- Set the filter to a group containing at least one switch.
The dashboard context for the group is displayed.
- Under , click > .
- Click the AOS-S or icon to view the switch configuration dashboard.
- To select a switch in the filter:
- Set the filter to or a group containing at least one switch.
- Under , click > .
A list of switches is displayed in the view.
- Click a switch under .
The dashboard context for the switch is displayed.
- Under , click .
The tabs to configure the switch is displayed.
- Click . The IGMP page is displayed with the list of existing VLANs.
- Select the VLAN row(s) for which you want to configure IGMP, and click .
- Select or from the drop-down.
- Click .
- To configure the switch to filter unknown multicast messages, move the toggle switch to the on position.
- Click .
