Configuring Access Policies on AOS-Switches
To restrict certain types of traffic on physical ports of AOS-Switches, you can configure ACLsAccess Control List. ACL is a common way of restricting certain types of traffic on a physical port. from the Aruba Central (on-premises) UI.
To create an access policy, complete the following steps:
- In the app, select one of the following options:
- To select a switch group in the filter:
- Set the filter to a group containing at least one switch.
The dashboard context for the group is displayed.
- Under Manage, click > .
- Click the AOS-S or icon to view the switch configuration dashboard.
- To select a switch in the filter:
- Set the filter to or a group containing at least one switch.
A list of switches is displayed in the view.
- Click a switch under .
The dashboard context for the switch is displayed.
- Under , click .
The tabs to configure the switch is displayed.
- Click > . The Access Policy page is displayed.
- Click + to add a new access policy. The page is displayed.
- Enter a name for the policy.
- Click .
- To add a rule to the access policy, click + under , and configure the following parameters:
- Click .
- Click .
The access policies must be applied to a switch port and the VLANVirtual Local Area Network. In computer networking, a single Layer 2 network may be partitioned to create multiple distinct broadcast domains, which are mutually isolated so that packets can only pass between them through one or more routers; such a domain is referred to as a Virtual Local Area Network, Virtual LAN, or VLAN. assigned to a port. For more information on access policy assignment to ports and VLANs, see the following topics:
