Configuring Loop Protection on AOS-Switch Ports
Enabling Loop Protection consumes CPUCentral Processing Unit. A CPU is an electronic circuitry in a computer for processing instructions. resources.
Loop protection provides protection against loops by transmitting loop protocol packets out of ports. For switches provisioned in UI groups, administrators can enable or disable loop protection on the switch ports or trunks by using the menu options available under app, > > .
Loop protection is always disabled by default on AOS-Switches. To configure loop protection for switches provisioned in the UI groups:
- In the app, select one of the following options:
- To select a switch group in the filter:
- Set the filter to a group containing at least one switch.
The dashboard context for the group is displayed.
- Under , click > .
- Click the icon to view the switch configuration dashboard.
- To select a switch in the filter:
- Set the filter to or a group containing at least one switch.
- Under , click > .
A list of switches is displayed in the view.
- Click a switch under .
The dashboard context for the switch is displayed.
- Under , click .
The tabs to configure the switch is displayed.
- Click > . The page is displayed.
- Depending on whether you want to configure a port or trunk, complete one of the following steps:
- In the tab, select the port(s), click .
- In the tab, select the trunk(s), click .
Table 1: Viewing or Configuring Port Settings
Name
Description
Value The number assigned to the switch port.
0 – 65535
Enables or disables loop protection.
or
Default:
Name of the trunk group to which the port belongs.
Dependent on the switch type.
Table 2: Viewing or Configuring Trunk Settings
Name
Description
Value Name of the trunk group to which the port belongs.
or
Default:
- Set loop protection to in the Loop Protection drop-down.
- Click .
- To auto-recover ports when the switch detects a loop, configure the following parameters.
- Disable Timer—Move the toggle switch to the on position to send an SNMPSimple Network Management Protocol. SNMP is a TCP/IP standard protocol for managing devices on IP networks. Devices that typically support SNMP include routers, switches, servers, workstations, printers, modem racks, and more. It is used mostly in network management systems to monitor network-attached devices for conditions that warrant administrative attention. trap when a port detects a disabled loop and manually re-enables the loop.
- Time (in secs)—Configure the time to auto-enable the Disable Timer. This field supports integers between 1 to 604800.
- Click .
