Configuring System Parameters for AOS-Switches
The menu under allows you to configure administrator credentials and enable mode for the switch users.
Configuring Administrator and Operator Credentials for AOS-Switches
To configure administrator credentials for AOS-Switches, complete the following steps:
- In the app, select one of the following options:
- To select a switch group in the filter:
- Set the filter to a group containing at least one switch.
The dashboard context for the group is displayed.
- Under , click > .
- Click the AOS-S or icon to view the switch configuration dashboard.
- To select a switch in the filter:
- Set the filter to or a group containing at least one switch.
- Under , click > .
A list of switches is displayed in the view.
- Click a switch under .
The dashboard context for the switch is displayed.
- Under , click .
The tabs to configure the switch is displayed.
- Click > . The page is displayed.
- Enter the username for the administrator user in the text box.
- Enter the password for admin in the text box and confirm the administrator password.
- To configure the operator user credentials, complete the following steps:
- Select the check box.
- Enter a username and password for the operator user.
- Confirm the password.
- Click .
Configuring a Name Server
To set a static IP for switches, you must configure a name server. To configure a name server, complete the following steps:
- Under , click > .
- Under , click > .
- Under , click .
- Click > .
- From the Name Server drop-down, select or . The default option is DHCPDynamic Host Configuration Protocol. A network protocol that enables a server to automatically assign an IP address to an IP-enabled device from a defined range of numbers configured for a given network. .
- You must add at least one DNSDomain Name System. A DNS server functions as a phone book for the intranet and Internet users. It converts human-readable computer host names into IP addresses and IP addresses into host names. It stores several records for a domain name such as an address 'A' record, name server (NS), and mail exchanger (MX) records. The Address 'A' record is the most important record that is stored in a DNS server, because it provides the required IP address for a network peripheral or element. server IP address, when you select Static in the drop-down.
- You can add only a valid IPv4 address.
- You can add a maximum of two DNS server IP addresses.
- The first static IP address that you add is considered as priority. The second IP address that you add is considered secondary.
- Enter the static IPv4 address of the DNS server in the text box.
- Click the + add icon.
- To delete a static IP address, click the
delete icon.If two IP addresses are configured, you can first delete the second priority IP address.
- Click .
