Switch > Overview > Routing
The Routing tab is displayed only for AOS-Switches that run the firmware version 16.09 or later.
In the switch dashboard, the Routing tab displays the following sections:
Viewing the Overview > Routing Tab
To navigate to the Routing tab in the Switch dashboard, complete the following steps:
  4. Under Manage, click OverviewRouting .
    The Routing tab is displayed.
    You can change the time range for the Routing tab by clicking the time range filter and selecting one of the available options: 3 hours, 1 day, 1 week, 1 month, or 3 months.
Overview of Routing Information
This section displays the following routing information:
  • Total—Displays the total number of routes on the switch.
  • Static—Displays the total number of static routes on the switch.
  • Connected—Displays the total number of connected routes on the switch.
Routing
The Routing table displays the following details:
  • Destination—Displays the network address of the destination route.
  • Gateway—Displays the IP address of the gateway.
  • VLAN—Displays the VLAN ID of the route destination.
  • Type—Displays the following types of routes:
    • Static—The routes that are manually added to the routing table in the switch.
    • Connected—The routes that are directly connected to the interface.
  • Sub Type—Displays the subtype of the route as Internal or External.
  • Metric—Displays the measure used to calculate the best path to reach the destination. A value of 1 indicates the best path, 15 indicates the worst path, and 16 indicates that the destination is unreachable on the route.
  • Distance—Displays the administrative distance of the route. The administrative distance helps routers determine the best route when there are multiple routes to the destination.
The routing information is displayed from the Aruba 3810 Switch Series and Aruba 5400R Switch Series in the network. The details displayed on the Routing tab are refreshed every five minutes.
Actions
  • Reboot—Reboots the switch. See Rebooting Switches.
  • Tech Support—Allows the administrators to generate a tech support dump for troubleshooting the device. See Troubleshooting Aruba Switches.
  • Console—Opens the remote console for a CLI session through SSH. Ensure that you allow SSH over port 443. The default user ID is admin, but you can edit and customize the user ID. This custom user ID must be mapped to the device. See Opening Remote Console for Switch.
For AOS-CX 8320 and 8325 switch series, you must enable SSH server on the default VRF. Add the ssh server vrf default code to the template.
