Client Live Events
Aruba Central (on-premises) allows you to troubleshoot issue related to client at both client device level and site level in real time for detailed analysis. Live troubleshooting is supported only if the wireless client is connected to the access point running Aruba Instant 8.4.0.0 or a later version. You can also enable packet capture during live troubleshooting and download the PCAP file if the access point is running Aruba Instant 8.6.0.5 or a later version.
The live troubleshooting can only be performed at a site level or for a specific client.
Live Events are supported only on Instant APs.
Troubleshooting a Client
To troubleshoot a client at a site level, perform the following steps:
- In the app, set the filter to one of the options under that contains at least one device.
The dashboard context for the selected site is displayed.
- Under , click .
The page is displayed.
- Enter the MACMedia Access Control. A MAC address is a unique identifier assigned to network interfaces for communications on a network. address of the client and click .
To troubleshoot a wireless or wired client, perform the following steps:
- In the app, set the filter to one of the options under , , or . For all devices, set the filter to .
- Under , click .
The clients overview page is displayed in view.
- By default, the table displays a unified list of clients.
- Click the name of the wireless or wired client to open the corresponding page. If there are many clients connected to the network, click or to filter the clients connected to the wireless or wired client respectively.
- Enter the client name in the column, and then click the client name.
- Under , click .
The client live troubleshooting starts automatically for the selected client.
The status of the troubleshooting is displayed every minute. The troubleshooting session runs for a duration of 15 minutes. You can stop live troubleshooting at any point by clicking and to go back to the historical view.
After the live troubleshooting session ends, the details of the events are displayed in the live events table.
Live Events Details
The following details are captured and displayed in the table:
- —Displays the timestamp of the event. Use the filter option to filter the events by date and time.
- —Displays the name of the device the client is connected to. Set the filter to select a specific device under .
- —Displays the type of device the client is connected to.
- —Displays the category of the event. Use the filter option to filter the events by category.
- —Displays a description of the event. Use the filter option to filter the events based on description.
You can download the list of live events to a CSVComma-Separated Values. A file format that stores tabular data in the plain text format separated by commas. file for offline analysis. To download live events, click the Download CSV
icon on the Live Events table.
Packet Capture
Aruba Central (on-premises) allows you to interact and launch a targeted packet capture on a client connected to a specific access point. Users with read-write and admin role can use live packet capture for troubleshooting devices. After you start packet capture from the UI, Aruba Central notifies the access point and the switch. The default packet capture duration is 15 minutes. After you start packet capture, use the toggle button to stop packet capture, or go back to the page.
Starting Packet Capture
You can start packet capture from the wireless or wired clients page. Packet capture can be done at a site level (wireless client only) or for a selected client.
To start packet capture at a site level, perform the following steps:
- In the app, set the filter to a that contains at least one device. The dashboard context for the selected site is displayed.
- Under , click .The page is displayed.
- Enter the MAC address of the client.
At a site level, Aruba Central (on-premises) does not support packet capture for a wired client connected to a switch.
- Enable the toggle button to start live packet capture for the selected client.
- Click .
To start packet capture for a wireless or wired client, perform the following steps:
- Under , click . The clients overview page is displayed in view.
- Enter the client name in the column, and click the client name.
- Under , click . The page is displayed. The client live troubleshooting starts automatically for the selected client.
- Click to stop live troubleshooting.
- Click to live troubleshoot the selected client. Live packet capture starts for the selected client.
The live troubleshooting session runs for a duration of 15 minutes. After the live troubleshooting session ends, a text appears above the live events table. Click to download the generated pcap file on your local system.
Packet capture can only be enabled or disabled before live troubleshooting is started. You cannot enable or disable packet capture while a live troubleshooting session is in progress.
Packet capture is not supported in single node deployments.
