Wi-Fi Connectivity
The Wi-Fi Connectivity page displays an overall view of the connection details for all clients that are connected to or tried to connect to each connection phase. The connection phases include Association, Authentication, DHCP, and DNS.
To view the connectivity details page complete the following procedure:
  1. In the Network Operations app, select one of the following options:
    To select a group, site, or all devices in the filter, set the filter to one of the options under Group or Site. For all devices, set the filter to Global.
  2. Under Manage > Overview, click Wi-Fi Connectivity.
By default, the graphs on the Wi-Fi Connectivity page is plotted for a time range of 3 hours. To view the graphs for a different time range, click the Time Range Filter icon. You can choose to view graphs for a time period of 3 hours, 1 day, 1 week, 1 month and 3 months.
This section includes the following topics:
Connectivity Summary Bar
The connectivity summary bar displays the details of all clients in percentage. It displays the percentage success rate of each stage for the users to know the network performance.
Figure 1  Connectivity Summary Bar
The following table describes the information displayed in each section:
Table 1: Connectivity Summary Bar
Field
Description
All
Displays the aggregated success percentage of Association, Authentication, and DHCPDynamic Host Configuration Protocol. A network protocol that enables a server to automatically assign an IP address to an IP-enabled device from a defined range of numbers configured for a given network.  for all clients connected to the network.
Association
Displays the percentage of successful attempts made by a client to connect to the network.
Authentication
Displays the percentage of successful attempts of client authentication.
DHCP
Displays the percentage of successful attempts of DHCP requests and responses when onboarding a client.
DNS
Displays the percentage of successful attempts in the detected DNSDomain Name System. A DNS server functions as a phone book for the intranet and Internet users. It converts human-readable computer host names into IP addresses and IP addresses into host names. It stores several records for a domain name such as an address 'A' record, name server (NS), and mail exchanger (MX) records. The Address 'A' record is the most important record that is stored in a DNS server, because it provides the required IP address for a network peripheral or element. resolutions, when a client is connected to the network.
Connection Experience
The Connection Experience tile displays the overall success percentage, total number of attempts, number of successful attempts, total delays, and the total failures for each stage based on the selected time range filter. To view the connection experience for individual stage, select the stage type from the Connectivity Summary bar, the Connection Experience displays the chart for the selected stage. Select All to view the success percentage for all the stages. You can hover over the time series graph to view the success percentage for a specific time. The individual stage displays the Attempts, Failures, Success, and Delays on the time series graph.
Figure 2  Connection Experience tile
AI Insights
The AI Insights tile provides a list of AI Insights generated for a selected time range. To view the details, click on a selected AI Insight. The page gets redirected to the AI Insights under the AI Insights page. Click each of the listed AI Insight for a detailed analysis based on the impact on the network. For more information on AI Insights, see The AI Insights Dashboard.
AI-Insights is not implemented for Association and DNS. AI Insights is not implemented at a Group level also. The page displays No AI Insights observed.
Connection Problems
The Connection Problems tile displays the details of Failures and Delays graphically for each of the categories from the drop-down list. Each graph displays the top five MACMedia Access Control. A MAC address is a unique identifier assigned to network interfaces for communications on a network. addresses or SSIDService Set Identifier. SSID is a name given to a WLAN and is used by the client to access a WLAN network. based on the selected category. Each category in the Connection Problems drop-down lists changes based on the selected stage in the Connectivity Summary bar. Selecting the required category from the drop-down displays the failures and delays in a pie chart with percentage, and a bar graph with the number of failures and delays. Hover the cursor over each graph to view the number of failures or delays for each stage.
Figure 3  Connection Problems Tile
The following table describes the information displayed in each connection category based on the selected stage:
Table 2: Connection Problems Rolls-ups
Data Pane Content
Description
All
Displays the details of the failures and delays that occurred during a client connection. The chart displays the failure details of Association, Authentication, and DHCP for each client. The Connection Problems drop-down list includes the following categories:
By Stage
By Clients
By Access Points
By Band
By SSID
Association
Charts the details of the failures and delays that occurred during a client association. The Connection Problems drop-down list includes the following categories:
By Clients
By Access Points
By Band
By SSID
By Reason
Authentication
Charts the details of the failures and delays that occurred during a client authentication. The Connection Problems drop-down list includes the following categories:
By Type
By Clients
By Access Points
By Band
By SSID
By Server
DHCP
Charts the details of the failures and delays that occurred during the attempts of DHCP requests and responses by a client. The Connection Problems drop-down list includes the following categories:
By Clients
By Access Points
By Reason
DNS
Charts the details of the failures and delays that occurred during the attempts in detected DNS resolutions when a client is connected to the network. The Connection Problems drop-down list includes the following categories:
By Access Points
By Reason
By Server
Connection Events
Connection Events table details out the list of delays and failures for each client based on the client MAC addresses. Click the icon to view the connection events table. Click the Connection Events drop down to filter the events By Clients or By Access Points. The Connection Events table displays the following information:
Table 3: Connection Events
Data Pane Content
Description
MAC Address
Displays the MAC address of the client.
Name
Displays the name of the access point.
Delays
Displays the delays that occurred during the event.
Failures
Displays the failure details that occurred during the event.
