Supported Aruba Mobility Controllers
Aruba Central supports provisioning, management, and monitoring of the following Aruba Mobility Controllers.
Supported Device |
Latest Validated Software Versions |
Aruba 7000 Series Mobility Controllers Aruba 7200 Series Mobility Controllers Aruba 9004 non-LTELong Term Evolution. LTE is a 4G wireless communication standard that provides high-speed wireless communication for mobile phones and data terminals. See 4G. Mobility Controllers |
8.8.0.0 8.7.1.0 8.6.0.7 6.5.4.16 |
Controllers running ArubaOS 6.5.4.8 software image do not support WebSocket connection. You must manually add these controllers to Aruba Central. The minimum software version required for monitoring controller clusters and Mobility Conductor managed networks is ArubaOS 8.2.1.0. |
