Creating a Group Persona with ArubaOS8 Architecture
To manage device configuration using configuration containers in Aruba Central, you can create a group and assign devices. During the group creation, you can assign a device persona and select an architecture for the group.
Adding a Group
To add a group and assign a persona and ArubaOS 8 architecture, complete the following steps:
- In the app, set the filter to .
- Under , click .
By default, the Network Structure tab is displayed.
- Click the tile.
The Groups page is displayed.
- Click (+) on the Groups table.
The Add Group page is displayed.
- Enter a name for the group.
The group name can be a maximum of 32 single byte ASCIIAmerican Standard Code for Information Interchange. An ASCII code is a numerical representation of a character or an action. characters if you use the UI to create the names. However, if you are using an NB APIApplication Programming Interface. Refers to a set of functions, procedures, protocols, and tools that enable users to build application software., the character limit increases to 128. A group name supports all special characters excluding the “>” character. System-defined group names such as “default”, “unprovisioned”, and “global” are not allowed in group names.
By default, Aruba Central enables the UI-based configuration. The template-based configuration is displayed only when you select devices in the Add group page. Use the toggle button to enable the Configure using templates.
- Select device types that will be part of this group. A group can contain following devices:
- Access points
- Controllers
- Switches
For detailed device combinations, refer to the Device Combinations table.
- Click Next.
By default the ArubaOS 8 architecture is applied for access points and controllers.
- Select the check box for Make these the preferred group settings optionally to save the architecture and persona settings of the current group for subsequent group creations.
- Click .
A group with persona configuration is created.
You can also create a group that uses different provisioning methods for switch, IAP, device categories. For example, you can create a group with template-based provisioning method for switches and UI-based provisioning method for Instant APs.
Device Combinations
The following table lists the valid combinations for a group persona with ArubaOS 8 architecture.
Table 1: Device Combinations for a Group Persona
Device Type |
Architecture |
AP Network Role |
Controller Network Role | Switches | Monitoring Only |
APs |
ArubaOS 8 |
Campus/Branch |
N/A |
N/A |
N/A |
Controllers |
ArubaOS 8 |
N/A |
Branch |
N/A |
N/A |
Switches |
No architecture |
N/A |
N/A |
Monitoring only for AOS-S |
ArubaOS 8 |
Campus/Branch |
Branch |
N/A |
N/A |
ArubaOS 8 |
Campus/Branch |
N/A |
ArubaOS 8 |
Campus/Branch |
Branch |
Editing a Group
You can edit a group to add a new device type to the group. The group architecture and persona cannot be changed through group edit. You can mark the settings of an edited group as preferred settings for subsequent group creations.
To edit a group, complete the following steps:
- From the app, filter .
- Under , click .
- Click the tile.
- To edit an existing group, hover over the group in the groups table and click the
icon.The Edit Group page is displayed.
- Add a new device type and its persona.
- For valid edit operations, refer to the Editing a Group table.
- Select check box for Make these the preferred group settings optionally to save the architecture and persona settings of the current group for subsequent group creations.
- Click .
The group edit changes are saved.
The following table lists the behavior for various edit operations:
Table 2: Editing a Group
Original State |
Action |
Edit Group Behaviour | |
Architecture |
Devices and Persona |
ArubaOS 8 |
AP - Campus/Branch No Controllers |
Allowed Controller persona - Branch Switch types: AOS-CX only or AOS-S only or Both AOS-CX and AOS-S |
ArubaOS 8 |
No AP Controllers - Branch |
Allowed AP persona - Campus/Branch Switch types: AOS-CX only or AOS-S only or Both AOS-CX and AOS-S |
No architecture |
No Access Points No Controllers Switches - AOS-CX only or AOS-S only or Both AOS-CX and AOS-S |
Allowed AP persona - Campus/Branch Controllers persona - Branch |
