Provisioning Devices Using Configuration Templates
Aruba Central (on-premises) allows you to provision devices using UI-based or template-based configuration method. If you have groups with template-based configuration enabled, you can create a template with a common set of CLI scripts, configuration commands, and variables. Using templates, you can apply CLI-based configuration parameters to multiple devices in a group.
If the template-based configuration method is enabled for a group, the UI configuration wizards for the devices in that group are disabled.
Creating a Group with Template-Based Configuration Method
To create a template group:
- From the app, filter .
- Under , click .
By default, the Network Structure tab is displayed.
- Click the tile.
The Groups page is displayed.
- Click (+) on the Groups table.
The Add Group page is displayed.
- Enter the name of the group.
The group name can be a maximum of 32 single byte ASCIIAmerican Standard Code for Information Interchange. An ASCII code is a numerical representation of a character or an action. characters if you use the UI to create the names. However, if you are using an NB APIApplication Programming Interface. Refers to a set of functions, procedures, protocols, and tools that enable users to build application software., the character limit increases to 128. A group name supports all special characters excluding the “>” character. System-defined group names such as “default”, “unprovisioned”, and “global” are not allowed in group names.
By default, Aruba Central enables the UI-based configuration. The template-based configuration is displayed only when you select devices in the Add group page. Use the toggle button to enable the Configure using templates.
- Select the device type for which you want to create a template group:
- Access points
- Controllers
- Switches
- Click Next.
By default the ArubaOS 8 architecture is applied for access points and controllers.
- Select the switch type for the group.
- Select the check box for Make these the preferred group settings optionally to save the architecture and persona settings of the current group for subsequent group creations.
- Click .
If the group is set as a template group, a configuration template is required for managing device configuration.
