Viewing Audit Trail
The Audit Trail page shows the total number logs generated for all device management, configuration, and user management events triggered in Aruba Central. Audit Trail logs provide users both user-initiated and system-initiated actions.
To view the Audit Trail logs perform the following steps:
  1. In the Network Operations app, use the filter to select a group or a device.
  2. Under Analyze, click Audit Trail. The Audit Trail table is displayed with the following details:
    • Occurred On— Timestamp of the audit log. Use the sort option to sort the audit logs by date and time. Use the filter option to select a specific time range to display the audit logs.
    • IP Address—IP address of the client device.
    • Username—Username of the admin user who applied the changes.
    • Target—The group or device to which the changes were applied.
    • Category—Type of modification and the affected device management category. It shows audit trail categories for system and user actions.
    • Description—A short description of the changes such as subscription assignment, firmware upgrade, and configuration updates. Click to view the complete details of the event. For example, if an event was not successful, clicking the ellipsis displays the reason for the failure.
To customize the Audit Trail table, click the eclipses icon to select the required columns, or click Reset to default to set the table to the default columns.
