Adding Mobility Controllers
You can add controllers using one of the following methods:
Adding a Controller using Controller Management
Adding Controllers Using a CSV File
Configuring SNMP and HTTPS Connection Profiles
To configure connection profiles for adding controllers:
1. In the Account Home page, under click .
The page is displayed.
2. Click .
The pop-up window opens.
3. Under , configure the SNMPSimple Network Management Protocol. SNMP is a TCP/IP standard protocol for managing devices on IP networks. Devices that typically support SNMP include routers, switches, servers, workstations, printers, modem racks, and more. It is used mostly in network management systems to monitor network-attached devices for conditions that warrant administrative attention. and HTTPSHypertext Transfer Protocol Secure. HTTPS is a variant of the HTTP that adds a layer of security on the data in transit through a secure socket layer or transport layer security protocol connection. connection profiles as per your requirement.
4. To add an SNMP connection profile:
a. Click and add the following details:
Name—Name of the connection profile.
—SNMP version, for example V2 or V3.
—Community string required for the management of controller.
b. Click .
5. To add an HTTPS connection profile:
a. Click HTTPS and add the following details:
—Username for HTTPS authentication.
and —Password for HTTPS authentication.
b. Click .
Adding a Controller
To add controllers using the tab:
2. Click .
3. Click tab.
4. Click + to add a controller.
5. Enter a name for the Mobility Master
6. Enter the IP address of the Mobility Master.
7. Select an SNMP or HTTPS profile.
8. Click .
This will auto discover the managed devices associated with the Mobility Master and add them to Aruba Central (on-premises).
9. Return to the page and verify if your controller is added.
Adding Controllers Manually
To add the controllers manually:
2. Click .
The pop-up window is displayed.
3. Enter the , , and of each controller. You can add up to 10 devices.
4. Click .
5. To configure the controller with the SNMP or HTTPS connection profiles and IP address, click the Controller's name and enter the following information:
- IP address of the controller.
- SNMP or HTTPS profile based on your requirement.
6. Click .
To import devices from a CSVComma-Separated Values. A file format that stores tabular data in the plain text format separated by commas. file:
1. Create a CSV file with the device list.
2. Ensure that the CSV file includes column headers for part number, MACMedia Access Control. A MAC address is a unique identifier assigned to network interfaces for communications on a network. address, serial number, and other optional fields such as firmware version and IP address of the device.
3. In the Account Home page, under click , click .
4. Browse to your local directory, select the CSV file, and then click .
5. Click .
