doc title Help Center
Supported Aruba Mobility Controllers
Aruba Central supports provisioning, management, and monitoring of the following Aruba Mobility Controllers.
Supported Device |
Minimum Software Version |
Latest Software Versions |
Aruba 7000 Series Mobility Controllers
Aruba 7200 Series Mobility Controllers |
ArubaOS 6.5.4.8
ArubaOS 6.5.4.8 |
8.4.0.4 (Branch Deployments only)
8.3.0.8 |
Controllers running ArubaOS 6.5.4.8 software image do not support WebSocket connection. You must manually add these controllers to Aruba Central. The minimum software version required for monitoring controller clusters and Mobility Master managed networks is ArubaOS 8.2.1.0. |
