Viewing the Controllers Tab
To view the Controller dashboard, complete the following steps:
1. In the app, set the filter to .
2. Click .
Controllers Dashboard
The dashboard page displays a complete list of offline or online controllers provisioned in Aruba Central. You can also use the following filtering options to view a specific set of controllers.
—Displays controller clusters deployed in Aruba Central. A controller cluster includes multiple controllers working together as a single managed entity. Controller clusters enable seamless roaming of clients between AP and ensure service continuity in the event of a failover. Controller clustering is supported only on devices running ArubaOS 8.x or later software versions. To view the cluster components, expand the cluster in the column.
—Displays a complete list of controllers.
—Displays a list of controllers that are functioning as Mobility Masters. The Aruba Mobility Master is an advanced master controller deployed as a virtual machine (VMVirtual Machine. A VM is an emulation of a computer system. VMs are based on computer architectures and provide functionality of a physical computer.) or installed on an x86-based hardware appliance. A single Mobility Master or a cluster of Mobility Masters oversees co-located controllers. It also displays the details about the APs associated with each controller.
