doc title Help Center
You are here: Home > Monitoring & Reports > Network Overview > Assigning Uplink Ports
To assign uplink port(s):
1. In the Network Operations app, set the filter to one of the options under Groups, Labels, or Sites. For all devices, set the filter to Global.
3. In the Switches table, hover over the switch for which you want to assign uplink port(s).
4. Click Uplinks.
For offline switches, click Actions > Uplinks in the pop-up window.
5. In the Assign Uplink Ports/Trunks dialog box, click the Assigned Uplink Ports/Trunks drop-down.
6. Select the port(s), and click Assign.
The following animation shows you how to assign uplink port(s):
