Viewing Audit Trail
The page shows the total number logs generated for all device management, configuration, and user management events triggered in Aruba Central.
To view the logs perform the following steps:
1. In the app, use the filter to select a group or a device.
2. Under , click . The table is displayed with the following details:
— Timestamp of the audit log. Use the sort option to sort the audit logs by date and time. Use the filter option to select a specific time range to display the audit logs.
—IP address of the client device.
—Username of the admin user who applied the changes.
—The group or device to which the changes were applied.
—Type of modification and the affected device management category.
—A short description of the changes such as subscription assignment, firmware upgrade, and configuration updates. Click
to view the complete details of the event. For example, if an event was not successful, clicking the ellipsis displays the reason for the failure.
To customize the table, click the eclipses |
