Configuring System Users
In the page, the option under allows you to create, modify, and delete users.
Adding a System User
To add a user, complete the following steps:
1. In the page, under , click .
The page is displayed.
2. Click .
The window is displayed.
3. Configure the following parameters:
—Email ID of the user. Enter a valid email address.
—Description of the user role. You can enter up to a maximum of 32 characters including alphabets, numbers, and special characters in the text field.
—Select a language. The Aruba Central web interface is available in English, French, Spanish, German, Brazilian Portuguese, Chinese, and Japanese languages.
—Select a user role for the page. If there are common modules between and other app(s), the user role has higher precedence. For example, the module in the app.
If an application is not provisioned, that application is not listed in the pop-up window. |
—Select a user role for the application.
If you assign the user role , , or , from the drop-down list, select group(s). By default, the user role has access to all groups.
4. Click . An email invite is sent to the user with a registration link. Users can use this link to access Aruba Central.
Resend Email Invite
If any user has not received the email invite, complete the following steps to resend the invite:
1. Click and slide the toggle button to the right.
2. Enter the email ID and click .
Viewing User Details
In the page, under , click . The tab opens. The table displays the following information:
Type of user. The user can be system user or external user.
Description of the user.
Role assigned for the application.
Role assigned for the page.
Allowed groups for the user.
Last active time of the user. If the last active time cell is blank, the user has not logged in after the product upgrade.
Editing a User
To edit a user account, complete the following steps:
The tab opens.
2. In the table, select the user and click the edit icon.
3. In the window, modify description, role, or allowed groups.
4. Click .
Deleting a User
To delete a user account:
The tab opens.
2. In the table, select the user and click the delete icon.
3. Confirm user deletion in the dialog box.
Viewing Audit Trail Logs for Users
Audit logs are generated when a new user is created and an existing user is modified or deleted from the Aruba Central account. It also records the login and logout activities of users.
To view audit logs for Aruba Central users:
The page opens.
2. To view audit logs for user addition, modification, or deletion, click the filter in the column, and select .
3. To filter audit logs about user activity, click the filter in the column, and select .
