Aruba Central Online Help
You are here: Home > Managing Access Points > Configuring Access Points
Configuring APs
This section describes how to configure WLANWireless Local Area Network. WLAN is a 802.11 standards-based LAN that the users access through a wireless connection. SSIDsService Set Identifier. SSID is a name given to a WLAN and is used by the client to access a WLAN network., radio profiles, DHCPDynamic Host Configuration Protocol. A network protocol that enables a server to automatically assign an IP address to an IP-enabled device from a defined range of numbers configured for a given network.  profiles, VPNVirtual Private Network. VPN enables secure access to a corporate network when located remotely. It enables a computer to send and receive data across shared or public networks as if it were directly connected to the private network, while benefiting from the functionality, security, and management policies of the private network. This is done by establishing a virtual point-to-point connection through the use of dedicated connections, encryption, or a combination of the two. routes, security and firewallFirewall is a network security system used for preventing unauthorized access to or from a private network. settings, uplink interfaces, and logging servers on access points (APs).
For more information on AP configuration, see the following topics:
