Provisioning Devices Using Configuration Templates
Aruba Central (on-premises) allows you to provision devices using UI-based or template-based configuration method. If you have groups with template-based configuration enabled, you can create a template with a common set of CLI scripts, configuration commands, and variables. Using templates, you can apply CLI-based configuration parameters to multiple devices in a group.
If the template-based configuration method is enabled for a group, the UI configuration wizards for the devices in that group are disabled.
Creating a Group with Template-Based Configuration Method
To create a template group:
- In the app, set the filter to . The dashboard context for selected filter is displayed.
- Under , click .
By default, the page is displayed.
- Click .
The pop-up window opens.
- Enter the name of the group.
- Select the device type for which you want to create a template group:
- IAP
- Switch
- Enter the password.
- Click .
If the group is set as a template group, a configuration template is required for managing device configuration.
Provisioning Devices Using Configuration Templates and Variable Definitions
For information on configuration template, see the following topics:
