Adding a Stack Member
Stacking allows you to add switches to the stack only when the conductor is active.
To add a switch to stack as a new member, complete the following steps:
- In the app, select one of the following options:
- To select a switch group in the filter:
- Set the filter to a group containing at least one switch.
The dashboard context for the group is displayed. - Under , click > .
- Click the icon to view the switch configuration dashboard.
- To select a switch in the filter:
- Set the filter to or a group containing at least one switch.
- Under , click > .
A list of switches is displayed in the view. - Click a switch under .
The dashboard context for the switch is displayed. - Under , click .
The tabs to configure the switch is displayed.
- Click . The Stacks page is displayed.
- In the table, select the stack row for which you want to add a member. The Members table displays the list of members for that particular stack. The table displays the following information:
Table 1: Members table
Name
Description
Value The name of the switch stack member.
A string
The MACMedia Access Control. A MAC address is a unique identifier assigned to network interfaces for communications on a network. address of the stack member.
Alphanumeric MAC address
The hardware model of the switch.
A String
The priority level of the stack member.
1 to 255
The role of a stack member.
Conductor, member, or standby
The status of the switch stack member.
Active, Inactive, or Not Joined
The name of the link and its corresponding port of the stack member.
A String
- In the table, click + to add a stack member.
The window is displayed. The following information is auto-generated:- Member ID—Identification number of the member.
- Priority—Priority of the member.
- Select the member using one of the following options:
- —Use this option when your conductor and member have the same model number.
- —Use this option when your conductor and member have different model numbers. Select the switch model from the model drop-down list.
- If the selected switch supports VSF Stacking, configure the following parameters:
- —Specify the name of the link 1 and its corresponding port.
- —Specify the name of the link 2 and its corresponding port.
- To add another stack member, click .
A message is displayed above the table when the maximum number of switches in a stack has been added.
- Click . After the stack members appear in table, connect the stacking modules and stacking cables to all switches and power on the switches.
Editing a stack member
To edit a stack member, select the member row you want to edit and click the edit icon.
Removing a stack member
To delete a stack member, select the member row that you want to delete and click the delete icon.
After removing a member, disconnect the switch from the stack. To disconnect the switch from the stack, do one of the followings:
- Turn off the power from the switch.
- Restart the switch using switch reset button.
You can remove only the stack member that has the lowest priority. For example, if there are three stack members with priority 254, 253 and 252 respectively and if you want to remove a stack member with priority 253, then first you need to remove the member with priority 252.
Priority cannot be assigned manually. Conductor switch is always assigned with priority 255. The priority of other subsequent members is decremented by 1.
