Creating an AOS-Switch Stack
To create an AOS-Switch stack, complete the following steps:
- In the app, select one of the following options:
- To select a switch group in the filter:
- Set the filter to a group containing at least one switch.
The dashboard context for the group is displayed. - Under , click > .
- Click the icon to view the switch configuration dashboard.
- To select a switch in the filter:
- Set the filter to or a group containing at least one switch.
- Under , click > .
A list of switches is displayed in the view. - Click a switch under .
The dashboard context for the switch is displayed. - Under , click .
The tabs to configure the switch is displayed.
- Click . The Stacks page is displayed.
The Stacks table displays the following information:Table 1: Stacks table
Name
Description
Value The name of the switch stack.
A string
The type of switch stacking.
BPS or VFS
The ID of the switch stack. The stack ID is auto-generated and cannot be changed in the settings.
Auto-generated String
The number of members on the switch stack.
Integer
The MACMedia Access Control. A MAC address is a unique identifier assigned to network interfaces for communications on a network. address of the switch stack.
Alphanumeric MAC address
The type of switch stack topology.
Chain, Ring, or unknown
The status of the stack formation.
Pending, In-progress, Active, or Failed
The port speed in the case of VSF stacking. This column is hidden by default. You must select the column from the columns list.
1G or 10G
- In the table, click + to add a stack.
The window is displayed. - Select a conductor switch from the drop-down list. The model number and serial number of switches are displayed in the drop-down list.
The conductor switch must be installed with the minimum supported firmware version of 16.06 or later.
If the selected switch supports VSF Stacking, configure the following parameters:
- —The name of the link 1 and its corresponding ports.
- — The name of the link 2 and its corresponding ports.
- —The domain ID of the switch stack.
- —The VSF port speed from the drop-down.
If the selected switch supports BPS stacking, insert the stacking module in switch and continue to step 5.
- Click . When the stack reboots, the status of the stack formation is displayed in the table. Do not make any changes to the stack until the status changes from In Progress to Active or Failed. If stack creation fails due to some issues, delete the stack entry and retry.
Editing a Stack
To edit a stack, select the stack row you want to edit and click the edit icon.
You can edit a stack only when its status is .
Removing a Stack
To remove a stack, select the stack row that you want to remove and click the delete icon.
You can remove a stack only when its status is .
