Express Configuration Using MultiEdit on AOS-CX
Express configuration provides a way to efficiently apply a predefined set of configuration settings to switches. Each set of configuration settings can contain settings for Network Analytics Engine (NAE) or device profile features.
To apply express configuration, complete the following steps:
- In the app, select one of the following options:
- To select a group in the filter:
- Set the filter to a group.
The dashboard context for the group is displayed.
- Under , click > .
- Click the or icon to view the AOS-CX switch configuration dashboard.
- To select a switch:
- Set the filter to or a group containing at least one switch.
- Under , click > .
A list of switches is displayed in the view.
- Click an AOS-CX switch under .
The dashboard context for the switch is displayed.
- Under , click .
The AOS-CX UI configuration page is displayed.
- To enable MultiEdit mode, move the toggle switch to the on position.
The page is displayed with the list of devices displayed in the table.
At the device level, the table lists only the switch that you have selected. Also, a pop-up is displayed on the bottom-right corner of the page with the options , , and . Go to step 6.
Search for a switch by entering a search query in the field.
For more information about search queries, see Using Device Search on AOS-CX.
- In the table, select one or more switches by clicking the corresponding rows.
A pop-up is displayed on the bottom-right corner of the page with options , , or .
- Click .
The Express Config (N) window is displayed. Where N represents the number of switches selected.
- Select the required feature from the drop-down. The following features are supported:
- Device Profile
- Network Analytics Engine
- Configure the following parameters corresponding to the selected feature:
Table 1: Device Profile Parameters
Name
Description
Value Enables or disables the device profile configuration on the switches.
Select or clear the check box.
Name of the device profile.
This field is pre-configured and cannot be edited.
VLANVirtual Local Area Network. In computer networking, a single Layer 2 network may be partitioned to create multiple distinct broadcast domains, which are mutually isolated so that packets can only pass between them through one or more routers; such a domain is referred to as a Virtual Local Area Network, Virtual LAN, or VLAN. mode for the device profile. Depending on the VLAN mode, configure one of the following:
- —ID of the access VLAN.
- ID of the native VLAN.
- Single or a range of allowed VLAN IDs.
Integer in the range
1to4094.PoEPower over Ethernet. PoE is a technology for wired Ethernet LANs to carry electric power required for the device in the data cables. The IEEE 802.3af PoE standard provides up to 15.4 W of power on each port. priority for the device.
Enables or disables processing of jumbo frames by the switches.
Table 2: Network Analytics Engine Parameters
Name
Description
Name of the NAE script. You can also configure the agent parameters.
The following NAE scripts are supported:
- —Monitors overall software device health.
- —Monitors overall hardware device health.
- —Monitors application health using TCPTransmission Control Protocol. TCP is a communication protocol that defines the standards for establishing and maintaining network connection for applications to exchange data. SYN and ACK packets, and VoIPVoice over IP. VoIP allows transmission of voice and multimedia content over an IP network. IP SLA sessions.
- —Monitors overall network health of device.
- —Monitors health of ports that are involved in spanning tree protocol.
- Click .
You can view the express configuration that you apply in the page if the state is off, or in the page if the state is on. For more information on viewing the pending changes, local overrides, and the configuration status, see Using Configuration Status on AOS-CX.
