Configuring Ports and LAGs on AOS-CX
Link aggregation group (LAGLink Aggregation Group . A LAG combines a number of physical ports together to make a single high-bandwidth data path. LAGs can connect two switches to provide a higher-bandwidth connection to a public network. ) bundles multiple physical EthernetEthernet is a network protocol for data transmission over LAN. links into one logical link. Link aggregation has the following benefits:
- Increased bandwidth beyond the limits of single link. In an aggregate link, traffic is distributed across the member ports.
- Improved link reliability. The member ports dynamically back up one another. When a member port fails, its traffic is automatically switched to other member ports.
From the Ports and Link Aggregation page, you can view all the ports, configure LAGs, and modify port settings for AOS-CX switches using UI groups.
Following are the maximum number of LAGs that are supported on AOS-CX switches:
- AOS-CX 4100i, 6100 switch series—8
- AOS-CX 6200 switch series—32
- AOS-CX 6300 switch series—256
- AOS-CX 8320, 8360 switch series—54
- AOS-CX 8325 switch series—128
AOS-CX 6400 and 8400 switch series are not supported in Aruba Central (on-premises) UI configuration.
Adding a LAG
To add a LAG, complete the following steps:
- In the app, select one of the following options:
- To select a switch group in the filter:
- Set the filter to a group.
The dashboard context for the group is displayed.
- Under , click > .
- Click the or icon to view the switch configuration dashboard.
- To select a switch in the filter:
- Set the filter to or a group containing at least one switch.
- Under , click > .
A list of switches is displayed in the view.
- Click an AOS-CX switch under .
The dashboard context for the switch is displayed.
- Under , click .
The AOS-CX UI configuration page is displayed.
- Click > .
The Ports & Link Aggregations page is displayed with the list of ports configured on the switch.
In the device view, all access ports are shown by default. Click the filter in the Name column to select All Uplink Ports or All Access Ports. You can also search for a port using the port name.
- In the table, click to add a Lag. The Add Lag window is displayed.
- Configure the following parameters:
>Table 1: Link Aggregation Parameters
Name
Description
Value
Name of the LAG.
Name starting with the string lag.
Example: lag1, Lag23, LAG123.
Description of the LAG.
A maximum of 64 characters including letters, numbers, and special characters, except question mark (?) and double quotes (").
The switch port members for the LAG.
Select from the drop-down list.
The speed and duplex configuration for the client traffic.
Speed Duplex is shown or hidden depending on the value in Port Members field
Indicates whether routing is enabled.
If routing is enabled at the device level, then specify the IP address with subnetSubnet is the logical division of an IP network. mask for the destination network. Format: (x.x.x.x/x).
If is enabled at the device level, then port authentication configuration is reset on all the selected ports.
Toggle the switch to on or off position.
The operational mode of VLANVirtual Local Area Network. In computer networking, a single Layer 2 network may be partitioned to create multiple distinct broadcast domains, which are mutually isolated so that packets can only pass between them through one or more routers; such a domain is referred to as a Virtual Local Area Network, Virtual LAN, or VLAN.. This field is available only when is disabled.
In the mode , port carries traffic only for the VLAN to which it is assigned. In the mode, a port can carry traffic for multiple VLANs.
or
For mode, an can be specified.
For mode, the and can be configured. You can enter multiple by specifying the range of VLANs or VLANs separated by comma.
For example, 1-7 or 55, 56, 57.
To specify the VLANs here, you must have already added the VLANs in the VLAN configuration page. See Configuring VLANs on AOS-CX.
The operational status of the LAG. If the check box is selected, then the LAG can receive and transmit data as long as a cable is connected and no physical or operational problems exists.
Select the check box to enable.
The operational mode of link aggregation control protocol (LACPLink Aggregation Control Protocol. LACP is used for the collective handling of multiple physical ports that can be seen as a single channel for network traffic purposes.).
LACP operates in these two modes:
- —When the LACP is operating in active mode on either end of a link, both ports can send Protocol Data Units (PDUs). The active LACP initiates an LACP connection by sending LACPDUs.
- —When the LACP is operating in passive mode on a local member port and its peer port, both ports cannot send PDUs. The passive LACP will wait for the remote end to initiate the link.
, , or .
- Click . The configured parameters are displayed in the table.
When the maximum number of LAGs are added for a switch, the + add icon is disabled.
Editing a LAG
To edit a LAG, point to the row for the LAG, and click the edit icon.
You can edit only one LAG at a time.
Deleting a LAG
To delete a LAG, point to row for the LAG, and click the delete icon.
Editing Ports settings
You can edit port settings by selecting one or more ports. If ports selected have different values configured, then changes made will be deployed on all the selected ports.
If a port is added to a LAG, then the port will not be displayed in the table.
To edit ports, complete the following steps:
- In the table, select one or more ports you want to edit and click the edit icon.
The Edit Ports window is displayed.
- To edit a single port, click the edit icon on the corresponding row.
- To edit multiple ports, select the rows you want to edit and click the edit icon in the <number of ports> item(s) selected window at the right bottom of the page.
- In the device view, all ports are shown by default. Click the filter in the Name column to select All Uplink Ports or All Access Ports. You can also search for a port using the port name.
- Edit the following parameters:
>Table 2: Ports Parameters
Table 3: Columns in the Devices Table in the MultiEdit Mode
Name
Description
Value
Description of the ports. When multiple ports are selected, then you can provide the same description for all the selected ports by selecting a check box. You can also provide different descriptions by clicking on the individual port fields.
A maximum of 64 characters including alphabets and numbers. Special characters are not allowed.
Select from the drop-down list. By default, is set to .
Indicates whether routing is enabled. If routing is enabled at the device level, then specify the IP address with subnet mask for the destination network. Format: (x.x.x.x/x), whereas IP address is not required at the group level.
The operational mode of VLAN. This field is available only when is disabled.
By default, a port is in mode and carries traffic only for the VLAN to which it is assigned. In mode, a port can carry traffic for multiple VLANs.
This option is not visible for VSF ports.
or
The operational status of the port. If the check box is selected, then the port can send and receive data as long as a cable is connected and no physical or operational problems exist.
- Click .
Editing OOBM Port
You can edit the Out of BandBand refers to a specified range of frequencies of electromagnetic radiation. Management (OOBM) port at the device level. To edit the OOBM port, complete the following steps:
- Select the port and click the edit icon.
The Edit Port OOBM page is displayed.
- —Method of IP assignment as or . Enter the IP address for IP assignment if the selected method is .
- —Operational status of the port. If the check box is selected, then the port can send and receive data as long as a cable is connected and no physical or operational problems exists.
- Click .
