Using Configuration Templates for AOS-CX Switch Management
Templates in Aruba Central (on-premises) refer to a set of configuration commands that can be used by the administrators for provisioning devices in a group. Configuration templates enable administrators to apply a set of configuration parameters simultaneously to multiple switches in a group and thus automate switch deployments.
  • To minimize configuration errors and troubleshoot device-specific configuration issues, Aruba recommends that the device administrators familiarize themselves with the CLI configuration commands available on AOS-CX switches.
  • The vsf member 1 line must be present in the configuration template for stackable AOS-CX switches running 10.07 or later versions. This is required to apply configuration to the switches. In case, if a template is applied to the switch that does not contain the vsf member 1 line, then the switch will be zeroized.
Creating a Group for Template-Based Configuration
For template-based provisioning, switches must be assigned to a group with template-based configuration method enabled.
For more information, see Creating a Group and Assigning Devices to Groups.
The Import Configuration As Template feature is supported only on AOS-CX switches running firmware version 10.06 or later.
Creating a Configuration Template
To create a configuration template for switches:
  1. In the Network Operations app, set the filter to a template group.
    The dashboard context for the group is displayed.
  3. Click the Config icon.
    The tabs to configure switches using templates is displayed.
  4. Click the Templates tab. The Templates page is displayed.
  5. Click + to add a new template. The Add Template window is displayed.
  6. In the Basic Info tab, enter a name for the template in the Template Name field.
  7. In the Device Type drop-down, select Aruba CX.
  8. Select the switch model and software version. You can specify any of the following combinations:
    • ALL for both Model and Version—To apply the template to all switch models and all supported switch software versions.
    • ALL for Model and a software version for Version—To apply the template to all switch models running the selected software version.
    • ALL for Version and a switch model for Model—To apply the template to a switch model and all software versions supported by the selected switch model.
    • A switch model and a software version—To apply the template to a specific switch model and the software version. The template created for a switch model and a software version takes precedence over the template that is created for all platforms and versions.
  9. Select the manufacturing part number of the switch in the Part Number drop-down.
  • The Part Number drop-down is displayed only if you select a switch model in the Model drop-down.
  • If you select a specific switch model and part number, you can apply the template to a standalone switch and not to a stack.
  • If you select All in the Model drop-down, or if you select a switch model and All in the Part Number drop-down, you can apply a template to both a standalone switch and stack.
  1. Click Next. The Template tab is displayed.
  2. Build a new template by adding the output of the show running-config from the switch CLI in the Template text box. Ensure that the template text adheres to the guidelines listed in the Important Points to Note.
  • You must manually create the template for the AOS-CX switch in a group, along with the password in plaintext format. You can use the output of the show running-config command to create the template. You can also add variables to use the same template for onboarding multiple AOS-CX switches. For more information on variables, see Managing Variable Files.
  • All switch templates must include a password command to set a password for the device. The template cannot be saved without adding a password command. If the configuration that is pushed from Aruba Central (on-premises) to the device does not contain a password command, the configuration push is aborted for the device and a log is added to the audit trail. For example, if you add the password command in a condition block and the condition evaluates to false, the configuration that is pushed will not contain the password command. For more information, see Managing Password in Configuration Templates.
  • For AOS-CX switches, you must configure the password only in plaintext. Also, the format of password must be user admin group administrators password plaintext <string>.
  1. Click Save. After you apply the configuration template, switches reboot and reconnect to Aruba Central (on-premises) with the new configuration.
Note the following points when adding configuration text to a template:
  • The CLI syntax in the switch template must be accurate. Aruba recommends that you validate the configuration syntax on the switch before adding it to the template text.
  • Ensure that the command text indentation matches the indentation in the running configuration.
  • The commands in the template are case-sensitive and cannot contain the % character. In the template-based configuration, the % character is reserved and is used to denote variables.
  • The following example illustrates the case discrepancies that the users must avoid in the template text:
    ssh server vrf default ssh server vrf mGmt vsf member 1 type jl660ab vlan 1 spanning-tree interface Mgmt no shutdown ip dhcp interface 1/1/1 no shutdown no routing vlan access 1 interface 1/1/2 no shutdown no routing vlan access 1 interface 1/1/3 no shutdown no routing vlan access 1 interface 1/1/4 no shutdown no routing vlan access 1 interface 1/1/5 no shutdown no routing vlan access 1 interface 1/1/6 no shutdown no routing vlan access 1 interface 1/1/7 no shutdown no routing vlan access 1 interface 1/1/8 no shutdown no routing vlan access 1 interface 1/1/9 no shutdown no routing vlan access 1 interface vlan 1 ip dhcp ! ! ! ! ! https-server vrf default https-server vrf MGMT
